Rebuilding Bottom end
Old Feb 17, 2007 | 08:35 AM
PWRDbyHseries's Avatar
Default Rebuilding Bottom end
Well ive decided that i want to rebuild the bottom end on my h22a1, i have the H22a in my car now but i want to get a lil higher compression. So just wondering what pistons would you suggest that i put in my H22a1??? Plannin on doin a fully build on the JDM later on down the road. So i want to yank that and put the US in.
Old Feb 17, 2007 | 08:38 AM
E-Money's Avatar
Default Re: Rebuilding Bottom end (PWRDbyHseries)
the jdm slugs that come with 11.0:1
Old Feb 18, 2007 | 12:39 PM
well i was thinkin on gettin the TypeS pistons but then again i was also thinkin bout JE, but im not sure on what size to go with., I would like to get something with 11 or higher compretion
Old Feb 18, 2007 | 06:32 PM
1 quick question.... What is the stock bore on an H22a1
Old Feb 18, 2007 | 06:34 PM
BlownH23a
Guest
Posts: n/a
ive got some jdm type S connecting rods if ur interested
Old Feb 18, 2007 | 06:43 PM
92hondalude's Avatar
Default Re: (BlownH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PWRDbyHseries &raquo;</TD></TR><TR><TD CLASS="quote">1 quick question.... What is the stock bore on an H22a1
87 mm
JE you have to sleeve
Old Feb 18, 2007 | 06:55 PM
Default Re: (92hondalude)
if i go with CP will i still have to sleeve??...... sorry of raskin about the bore i shoulda checked the faqs
Old Feb 18, 2007 | 06:58 PM
nonvteclude's Avatar
Default Re: (PWRDbyHseries)
yes you will have to sleeve with them all except for the type s. there is the mahle golds (i think thats them) that say are good with frm but have seen a few horror stories with them still.
Old Feb 18, 2007 | 06:59 PM
doubledeucehatch's Avatar
BUMP
Old Feb 18, 2007 | 07:15 PM
well in this case, i think that i might go with a set of OS .025 TypeS pistons. Now if i get those would it be best for me to get the set of typeS connecting rods also.
Old Feb 18, 2007 | 07:16 PM
just keep yours and mod the for floating wrist pins. also do a search on them you will find alot of info
Old Feb 18, 2007 | 08:34 PM
BlownH23a
Guest
Posts: n/a
Default Re: (nonvteclude)
or you can get these type s rods off my hands for a very good price and have the peace of mind that everything is as it should be...
Old Feb 19, 2007 | 10:00 AM
OK well i think that im goin to try and get the TypeS pistons and rings from JHPusa.com and then try and get the TypeS Rods from here...
Old Feb 19, 2007 | 10:16 AM
98vtec's Avatar
moderator emeritus
eagle makes a connecting rod specifically for Type S pistons.....
Old Feb 19, 2007 | 12:14 PM
BlownH23a
Guest
Posts: n/a
Default Re: (98vtec)
Old Feb 19, 2007 | 12:44 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlownH23a &raquo;</TD></TR><TR><TD CLASS="quote">$$$$$</TD></TR></TABLE>
not really that expensive.
CRS5630J3D 5.630" Honda H22A4 engines for use with JDM Type S pistons $302 shipped
https://honda-tech.com/zerothread/1597107
Old Mar 5, 2007 | 12:56 PM
well here really soon im goin to try and get JDM typeS pistons(standard) and typeS rods.... well i looked on majestic honda and they want like 35 for rings, so i called honda and they want 50, well then i looked on JHPUSA.com and they want 150... what would the difference be and what would you do????
Old Mar 5, 2007 | 02:38 PM
117's Avatar
117
OEM rings.
trooper0641
Feb 17, 2008 05:29 PM
Integra414vteC
May 17, 2007 06:50 PM
vtec420kingH22
Oct 14, 2005 06:45 PM
Citystar
Jun 23, 2004 06:20 PM
igo4bmx
May 18, 2004 05:24 PM
