Car smoking
Old May 20, 2002 | 09:04 AM
PMTypeR's Avatar
Default Car smoking
Yup it's smoking again!
My car smokes when I hit 8000 rpms or higher. I had this problem last summer, SO this past winter I had all of my oil rings replaced because I thought that would solve the problem. Apparently not. What do you guys think?
Bad Oil ring install?
Bad Valve Guides?
Thanks
Old May 20, 2002 | 09:23 AM
project EK's Avatar
Default Re: Car smoking (PMTypeR)
does it smoke up only when you stop at idle? or while your gasing it?...
Old May 20, 2002 | 09:24 AM
Hybrid ctr's Avatar
Default Re: Car smoking (project EK)
read his post, smokes at 8000+rpm
Old May 20, 2002 | 09:25 AM
reefer_bob's Avatar
Default Re: Car smoking (Hybrid ctr)
What color is the smoke? Maybe it's just running too rich at the high RPM range, and you're getting excess fuel...
Old May 20, 2002 | 09:30 AM
PMTypeR's Avatar
Default Re: Car smoking (reefer_bob)
it's white smoke
so I was thinking oil.
Old May 20, 2002 | 09:35 AM
uNF$@#!'s Avatar
white smoke? are you submerging your filter in water again
Old May 20, 2002 | 09:39 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Car smoking (00-0187)
mine smokes black during acceleration, but I'm running rich as hell. It also smokes out the window when I'm smokin' a fatty cowboy killer
Old May 20, 2002 | 09:41 AM
Hybrid ctr's Avatar
Default Re: Car smoking (RealTypeR)
when do you see blue smoke?? I can't remember
adam's Avatar
blue = oil
Old May 20, 2002 | 09:42 AM
PMTypeR's Avatar
I have that problem from time to time too
Old May 21, 2002 | 06:32 AM
PMTypeR's Avatar
ttt
anyone else have any ideas/suggestions?
Old May 21, 2002 | 07:10 AM
onyx00's Avatar
How bad is the smoking? got any pictures or video?
Old May 21, 2002 | 07:49 AM
PMTypeR's Avatar
Default Re: Car smoking (onyx00)
it's not that bad I guess
It only does it when if I rev up to 8000 + and let off the gas... and the engine revs down.
Old May 21, 2002 | 08:17 AM
Racebrewer's Avatar
If its smoking blue while you are accelerating, its a ring problem.
If its smoking blue on deceleration (e.g. at shift points or when you let off on the gas after accelerating) its likely valve seals or guides. Oil is being pushed down the guides. Check PCV while you're at it.
John
Old May 21, 2002 | 03:36 PM
EagleR's Avatar
Default Re: Car smoking (Racebrewer)
white smoke is H2O related i thought, and blueil and black =rich fuel mix
Old May 21, 2002 | 05:15 PM
csufweed's Avatar
Default Re: Car smoking (EagleR)
white smoke is nothin... just water.
Old May 21, 2002 | 05:21 PM
EagleR's Avatar
Default Re: Car smoking (csufweed)
Thats what i thought too...thanx for jumpin in
Old May 21, 2002 | 05:22 PM
ALLMOTOR18's Avatar
could be a leaky headgasket..
Old May 21, 2002 | 06:30 PM
PMTypeR's Avatar
Default Re: Car smoking (GSRTypeR)
water???
damn I thought it was oil..
Is there any way I can correct this problem.
I have the Mugen headgasket.
Old May 21, 2002 | 06:40 PM
Razor's Avatar
blue/black smoke : oil rings, other engine oil problems
white (milky) smoke : coolant leak into combustion chamber, has to do with coolant
Old May 21, 2002 | 07:15 PM
bearingburner's Avatar
white=water
black=rich ratio
blue=motor oil
grey=atf
are you able to inspect your car from under neath. check if any exhaust gaskets are leaking water. when a car runs very efficient it produces co2 and water. of course the water is not drinkable. if white smoke appears only at 8000 rpms then there must be some water in the muffler area and/or the resonator. i have the same condition and no gasket leaks and/or oil leaks
hadden
11
Aug 7, 2013 10:57 AM
B18cFreak
Apr 17, 2007 02:04 PM
egdriver94
12
Aug 20, 2006 07:21 PM
KustomCrx
Aug 26, 2004 11:16 PM
deSigi
10
Aug 24, 2004 08:30 PM
