transmission swap
You would have to Find a transmission with a LSD already in it... or you would have to BUY and LSD diff. and put it in your transmission, Which isnt somthing that you would be able to do unless you know how to take a transmission apart..
And i think a quality brand lsd diff like quaife is around 800 bucks...
i need to replace my trans anyway, and i found one on a jdm sight with an lsd already added to it. i was just making sure i don't need any exra parts or if the axles would be diferent
can anyone answere me this question is there much diference between the standard trans and one with lsd.. is it worth the additional money.
only thing a LSD allows you to do is to get traction when one wheel is on a good surface and the other wheel is on a bad surface and it also helps with torque steer and turning while accellerating. in a car tunned for handling it is worth it IMHO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by YeuEmMaiMai »</TD></TR><TR><TD CLASS="quote">only thing a LSD allows you to do is to get traction when one wheel is on a good surface and the other wheel is on a bad surface and it also helps with torque steer and turning while accellerating. in a car tunned for handling it is worth it IMHO</TD></TR></TABLE>In any car where you want both wheels to lock up, LSD is a must... it is not just for handling.
