Vtec Controller, Good or Loose Power?
Old Feb 16, 2007 | 10:11 PM
preludeh22a1's Avatar
Default Vtec Controller, Good or Loose Power?
i have the sfc vtec controller, i set the vtec 4500rpm bcoz i have a auto trans, but the car chokes sometimes. I put it today to 5500rpm and it runs fine. Is it ok to put the vtec higher? or Lower?what should be a good setting? On power or acceleration basis? any info will help.
Old Feb 16, 2007 | 10:33 PM
Hawkze_2.3's Avatar
Default Re: Vtec Controller, Good or Loose Power? (preludeh22a1)
You need to dyno your car to find the optimal VTEC crossover point.
You have a 5th gen auto?
Old Feb 19, 2007 | 03:07 AM
92 to 96 prelude, the car is 92 with 96 h22a1. yup its auto...sucks sometimes.. well ive set it back to 5000.
Old Feb 19, 2007 | 04:29 AM
Apex1972's Avatar
Swap in a manual. Take out the AFC.
Old Feb 19, 2007 | 07:18 AM
1GPlusSH's Avatar
If your motor is stock, keep your vtec engagement stock. otherwise, dyno your car, and see where you need to put it.
Old Feb 19, 2007 | 01:25 PM
doubledeucehatch's Avatar
You vtec crossover should be smooth when you dyno it. So when you power starts to drop off thats when vtec should engage
Old Feb 19, 2007 | 04:35 PM
GoldLudeRay's Avatar
if it is chokeing try leaning out the mixture.
or use the unmatch function and lean tha out too. dyno,dyno,dyno, and adj timming, and cam gears then the vafc isnt that bad. but if ur going for max hp go stand alone or chippable ecu. vac is the hack method but you can get them for cheap sometimes
Old Feb 19, 2007 | 04:49 PM
Chuckles99SH's Avatar
Default Re: (GoldLudeRay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoldLudeRay &raquo;</TD></TR><TR><TD CLASS="quote">if it is chokeing try leaning out the mixture.
or use the unmatch function and lean tha out too. dyno,dyno,dyno, and adj timming, and cam gears then the vafc isnt that bad. but if ur going for max hp go stand alone or chippable ecu. vac is the hack method but you can get them for cheap sometimes</TD></TR></TABLE>
Dont give him ideas, or he might blame you for blowing up his motor with bad advice. I would take it out if you dont know what your doing and you obviously dont. Stand alone is the only way to go for a proper tune, next is piggyback then chipped ecu, chipped ecus tend to be great ***** of crap imo. VAFC is a piggyback not a hack retard, its not that much cheaper than say Emanage, which has a few more options.
Egg Driver
Jun 8, 2010 04:13 PM
RJH6
Apr 12, 2004 03:37 PM
EsQueue
Jul 8, 2003 03:15 PM
af97civic
Jun 18, 2003 08:04 AM
Ri5e
Aug 27, 2002 02:54 AM
