FS: AEM AIR BYPASS VALVE Cold Air Intake
Old Feb 16, 2007 | 10:07 PM
themilman's Avatar
Default FS: AEM AIR BYPASS VALVE Cold Air Intake
Brand new, never used, AEM Air Bypass Valve, part number 20-401. If you've got a cold air intake and you live anywhere it rains you need this.
Ever wonder how much water it takes to blow up your engine? Also known as hydro-lock? Two tablespoons. Two tablespoons of water in a cylinder will take up sufficient room to generate enough extra pressure to make your engine go boom.
Boom is bad, Air bypass is good.
You don't have to worry about your intake sucking hot engine air from your engine compartment through this valve. Its engineered so that it will ONLY let air through IF your other air filter is submerged in water. It requires a certain amount of vacuum so under normal conditions your cold air intake functions as normal even with the bypass valve installed, genius, thank you AEM.
$25 + $8 shipping anywhere in the US.
Email me if your interested, themilman@hotmail.com
Check out this review by SportCompactCar for more information: http://www.sportcompactcarweb....alve/
Old Feb 17, 2007 | 05:29 PM
themilman's Avatar
Default Re: FS: AEM AIR BYPASS VALVE Cold Air Intake (themilman)
bump
Old Feb 19, 2007 | 07:29 PM
themilman's Avatar
bump it up
Old Feb 20, 2007 | 07:27 PM
themilman's Avatar
bump TTT^^^
Old Feb 22, 2007 | 07:26 PM
themilman's Avatar
bump
Old Feb 24, 2007 | 11:58 PM
themilman's Avatar
bump
Old Feb 25, 2007 | 09:52 PM
themilman's Avatar
bumpTTT^^^
Old Feb 27, 2007 | 09:41 PM
themilman's Avatar
bump
APAem1
Jul 4, 2010 05:18 PM
deinon
Jun 3, 2006 12:30 AM
Ch3miztry
Mar 14, 2005 03:15 PM
Hairy Gorilla
Oct 29, 2002 10:47 AM
flipn0y
Jun 2, 2002 09:36 AM
