help or any suggestions
My dc2 took a ****......there is no spark, no fuel and all the light on the cluster is dead.......swap distributor unit, ecu and check all necessary things..........when the key is turn on the only thing you hear is the chirping noise (indicating key in inginition)........cluster is black, no power to fuel pump, no fuel pressure and no spark.......the last thing i did not change is the main relay.......i'm wondering if the main relay controls the spark along with the fuel cut off........help or any suggestion...
no....the main relay works....i tried it on another car.....found out the problem....it was the ignition part of the lock and tumbler
yes, there is no light on the cluster and i did everything you name and narrow it down to the ignition switch........there was power to it and all, but gave a me a faulty reading.....so i went ahead and changed it out and everything works......thanks for the suggestions......
wtfisvtec??
38
Jun 30, 2024 05:13 PM
SiR-G DC
Aug 20, 2009 08:04 AM
white90crxhf
12
Aug 17, 2006 09:16 PM
