does the valve cover gasket have...
Old Feb 16, 2007 | 01:19 PM
budget's Avatar
Default does the valve cover gasket have...
does the valve cover gasket have an actual side that is used for 'front and back' or does it not matter?
also is the gasket suffient enough or do i need to use hondabond before i put the valve cover back on?
Old Feb 16, 2007 | 01:22 PM
WhiteBB2's Avatar
Default Re: does the valve cover gasket have... (budget)
theres only 1 way the gasket will go on...
Rosko's Avatar
it only goes on one way, the timing cover side has two little chunks of rubber poking out from the rest of it. a dab of hondabond in the corners by the cam caps should be sufficient.
depo
Mar 23, 2019 09:37 PM
lll
Feb 16, 2007 03:30 PM
porter
Feb 16, 2007 01:46 PM
type Gendy
10
Sep 6, 2003 10:44 AM
B18C-Hatch
May 19, 2003 02:44 PM
