Cant get timing belt on
Old Feb 16, 2007 | 12:10 PM
hyabusa hunter's Avatar
Default Cant get timing belt on
hey guys, been trying to get my timing belt on for 4 hours now after doing a manual tensioner conversion....... i have a "Greddy" performance timing belt.
i have searched.
my question is????? will a H23 OEM honda timing belt be just as good? cause i have one in my shed running 466hp.
fairly urgent
Old Feb 16, 2007 | 12:24 PM
Rosko's Avatar
Default Re: Cant get timing belt on (hyabusa hunter)
h22 and h23 timing belts are different. are you putting the belt on in a counterclockwise direction? start at crank gear and go around from there. its a tight fit so it helps to have a helping hand keeping the tension on everything.
Old Feb 16, 2007 | 01:28 PM
nikolai.'s Avatar
here's what i did.
pull the manual tensioner off
put the belt on the crank
put the belt on the exhaust cam gear
put the belt on the intake cam gear
put the belt on the water pump
place the tensioner bearing onto the mounting bolt to tension the belt.
Old Feb 16, 2007 | 02:01 PM
Default Re: (nikolai.)
thanks for the replies fellows!
i cant seem to get the tensioner back on properly, i cant get the the tensioner located onto the "nipple" thats hold it in place!
Modified by hyabusa hunter at 4:13 PM 2/16/2007
Old Feb 16, 2007 | 02:19 PM
flyrod's Avatar
Default Re: (hyabusa hunter)
I think one guy posted here that he had to grind clearance in that back part of the bearing. Check the FAQ. There is an entire thread dedicated to the manual tensioner install on a H22. Here is the page describing modification of the bearing:
https://honda-tech.com/zero...ge=10
Old Feb 16, 2007 | 03:14 PM
Default Re: (flyrod)
thanks for the help
im not using the tri-angluar bracket, so the bolt is no relavant in my case,
Old Feb 16, 2007 | 03:44 PM
fastlude69's Avatar
i start at the crank and work my way around and do the exhaust came then put onto the intake cam gear last
Old Feb 16, 2007 | 03:50 PM
PrettyLude's Avatar
seems like your not pushing the tensioner down enough
Old Feb 16, 2007 | 06:26 PM
RaceCity_USA's Avatar
Banned
Push the tensioner against the spring pull as far as it will go, then tighten the tensioner bolt to hold it there. That will give you the maximum amount of slop in the belt.
Old Feb 16, 2007 | 06:30 PM
M2B4's Avatar
Default Re: Cant get timing belt on (RaceCity_USA)
yep i loosened the tensioner and pushed it down as far as i could. tightened that bolt. had 3 big tip flat head screw drivers and slid that bitch on. was a PITA
Old Feb 16, 2007 | 06:31 PM
SteveoBA8's Avatar
Default Re: Cant get timing belt on (M2B4)
It's a **********, be paitent.
Old Feb 17, 2007 | 03:41 AM
thanks giys for all the help anf advice! im just about to tackle it again! ill let you know how i get on with it!
Old Feb 17, 2007 | 05:25 AM
do have have to use the balancing belt pulley which bolts on after the tensioner pulley? i have machined a spacer to " fill" the space.
im not using the balancer belt either.
Old Feb 17, 2007 | 05:31 AM
all good, got the belt on......by myself, pat on the back from me. yay yay yay. i found the answer to my question too. lets put her back together again,
7 hours later...... patience is the secret. and sore fingers
Old Feb 17, 2007 | 07:59 PM
PrettyLude's Avatar
what was the problem?
ludekid4323
Oct 20, 2009 09:28 PM
ragnarok0mega
Sep 16, 2009 08:35 PM
TravisCadello
17
Apr 18, 2009 06:18 AM
kornerk12
Nov 25, 2007 02:03 PM
precord96
Mar 4, 2005 05:51 PM
