ARP products for h22 pressure plate and flywheel
Old Feb 16, 2007 | 08:06 AM
kornerk12's Avatar
Default ARP products for h22 pressure plate and flywheel
Well for the flywheel it says for bseries but will it work for us ? For the pressure plate bolts it says that DOHC has 9 pieces when theres only 6 bolts on hseries pressure plates and for SOHC it says 6 pieces. Will either of these work for the lude ?
Old Feb 22, 2007 | 06:57 PM
kornerk12's Avatar
Default Re: ARP products for h22 pressure plate and flywheel (kornerk12)
bump
Old Feb 23, 2007 | 02:31 AM
117's Avatar
117
What's wrong with OEM bolts?
Old Feb 23, 2007 | 06:11 AM
kornerk12's Avatar
Default Re: (117)
I was thinking maybe arp cause the stock stuff has alot of miles plus when u go with aircraft grade stuff you know u NEVER have to really worry about it unless its install error.
Old Feb 23, 2007 | 07:15 AM
117's Avatar
117
I've never seen anyone break OEM flywheel bolts and/or pressure plate bolts. Replace them if you're worried about them.
Old Feb 23, 2007 | 04:16 PM
PrettyLude's Avatar
man those bolts from the factory are pretty tough to break, you got to be doing something really dumb to break one of those
Old Feb 23, 2007 | 05:40 PM
kornerk12's Avatar
Default Re: (PrettyLude)
will the arp ones work and will the sohc or dohc ones be the ones i want ?
Old Feb 25, 2007 | 09:24 AM
kornerk12's Avatar
Default Re: (kornerk12)
bump
Old Feb 25, 2007 | 09:45 AM
championshipwhite93si's Avatar
oem FTW. ive seen arps break.. rod bolts, mains.... you name it, its rare to see a oem bolt break UNLESS its a 10mm tiny one, and for some reason, i break those all the damn time trying to tighten them..
Old Feb 25, 2007 | 10:28 AM
MLBZ521's Avatar
Default Re: (championshipwhite93si)
^^I've broken the Head Bots (Cam Plate Bolts, Bolts Holding the Cam Plates onto the Head). Both the Small ones and larger ones... ALWAYS replace these in my opinion... Used = Asking for bad outcome...
OP, Do you really just not want to use the OEM Flywheel bolts for some reason??
Old Feb 25, 2007 | 10:34 AM
117's Avatar
117
I think he believes ARP is just that much better than stock. I prefer just to use stock myself. The only thing I'd want over stock would be bolts with the head drilled so I can safety wire them.
Old Feb 25, 2007 | 02:22 PM
kornerk12's Avatar
Default Re: (117)
no i just want to know if they will work a friend of mine has a set he didnt use and will give them to me for free, i wanted to know if the pitch and length and head size is the same.
Old Feb 25, 2007 | 04:43 PM
117's Avatar
117
Why not compare the two?
IIRC the flywheel bolts are a very uncommon size: M12x1.00. Pressure plate bolts are M8x1.25. I'd have to double check, but I'm 99.9% sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kornerk12 &raquo;</TD></TR><TR><TD CLASS="quote">no i just want to know if they will work a friend of mine has a set he didnt use and will give them to me for free, i wanted to know if the pitch and length and head size is the same. </TD></TR></TABLE>
Silvertc
Jun 11, 2010 10:23 AM
GT40eg
Jul 1, 2007 08:01 PM
kuja
Jul 5, 2005 08:51 PM
Chillinit
Mar 12, 2005 10:58 AM
