Prelude Shift linkage ?
Is it all the same length 4th gen, 5th gen base and SH ? I know you need the shifter for the 4th gen if u have 4th gen linkage and 5th gen shifter with 5th gen linkage.
from what i could tell, the lengths are the same between 4th gen and 5th gen. the shifter plates just mount a little differently to the car and the shift cables mount differently between the 4th and 5th gen. base and SH are identical.
Everything is the same between the Base and SH, but the 4th Gen shifter has a different plate so you'll need to modify that to make it work...Which I also believe an Accord shifter will work as well
