need help on info of displacement
Im planning on building an LsVtec but kinda stuck on deciding to sleeved the sleeves or not.
The plan is using Blox C cams, valvetrain rev up to 9k, Cp 11.5:1 compression, ARP rods and head studs.
Will my stock B18a1 sleeves handle this? or do i have to sleeved it?
you can use those sleeves....it depends how large of a bore of piston you going to use...stock bore is 81mm...
stock sleeves will handle 81.5mm...I have heard stock will do 81.75..
so the max i can bored out is .5 - .75 and still stay in safe zone w/o sleeved them.
thanks alot.
and base on my info of the plan will i be able to hit 220 whp?
thanks alot.
I would do .5 over..wouldnt stretch it to .75..
actually dont bore unless you really need to.. I wish I could have stayed at 81mm...then I dont have to worry about my sleeves slipping when I dyno next sat.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by smileycvc »</TD></TR><TR><TD CLASS="quote">probally not. I think you need more compression and a bigger bore. Some some of the best bolt ons ever made. </TD></TR></TABLE>
I agree and disagree...bigger bore would help but not necessarily higher compression pistons...11.x compression pistons should work fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16nonoy »</TD></TR><TR><TD CLASS="quote">just get a stroker kit..if you go longer bore..you need a longer stroke to balance everything out..</TD></TR></TABLE>
hmmmm...i doubt they make a stroker kit for LS blocks...bigger bore doens't necessarily mean bigger stroke.
