Golden Eagle Ls-v kit
Old Feb 15, 2007 | 04:24 PM
JFG Kevin's Avatar
Default Golden Eagle Ls-v kit
Is the kit known to leak from using a certain oil filter? I'm using fram and it's started leaking...Has anyone else have had this problem before?
Old Feb 15, 2007 | 05:17 PM
NAlover's Avatar
Default Re: Golden Eagle Ls-v kit (JFG Kevin)
NO sir
3 car that I know with the G.E kit don't leak
Old Feb 15, 2007 | 09:18 PM
JFG Kevin's Avatar
Default Re: Golden Eagle Ls-v kit (NAlover)
Thank you for the reply...probably a bad oil filter...hum...my luck...only..gosh..!!
Old Feb 15, 2007 | 10:15 PM
smileycvc's Avatar
did u take the old rubber gasket off of the old filter
Old Feb 15, 2007 | 11:12 PM
JFG Kevin's Avatar
Default Re: Golden Eagle Ls-v kit (smileycvc)
it was a fresh motor...never had a filter on..this is the first filter i put on there...
Old Feb 16, 2007 | 09:14 AM
smileycvc's Avatar
that sucks
Old Feb 16, 2007 | 09:54 AM
pomansouth01's Avatar
Ginger Kid
first thing I would change is the oil filter, Fram has been known to break apart and starve rod and main journals of oil...
Old Feb 16, 2007 | 09:58 AM
JFG Kevin's Avatar
Default Re: (pomansouth01)
i've been using fram for a while now...i just change the oil and filter...still leaking...dont know what's goin on...I'm wonderin if it's even the kit anymore..can't tell..cause there's oil all over the place...gotta take a closer look....It only happens when i drive..not when i'm at idle...
Honda Type R
Aug 16, 2016 09:20 AM
LUDEcidDream
Mar 2, 2011 10:11 AM
bigsnorlax
Nov 6, 2009 06:43 AM
SCHYBRID
Apr 6, 2002 08:03 AM
