BLOX IM, what bolts/studs do I need?
Old Feb 15, 2007 | 01:55 PM
boomersz's Avatar
Default BLOX IM, what bolts/studs do I need?
EDIT: what do i do about the EVAP solenoid and vaccum? i don't think my swap came with one or if it was supposed to, 94 gsr
I got the ones for the TB already, what size do I need for the fuel rail and anything else?
Also can I reuse the TB gasket?
And what all do I need to transfer over from the gsr IM to the new one? I got the fuel rail and TB, what else?
Modified by zoo at 6:58 PM 2/15/2007
Modified by zoo at 12:50 AM 2/20/2007
Old Feb 15, 2007 | 02:43 PM
imacoolkid's Avatar
Default Re: BLOX IM, what bolts/studs do I need? (zoo)
hey man just use your stock ones from your old manifold. i have skunk 2 and used mine from my gsr manifold just screw out and screw in and you're done. and yeah you should be able to use your same gasket...i did
Old Feb 15, 2007 | 02:46 PM
boomersz's Avatar
Default Re: BLOX IM, what bolts/studs do I need? (cmillertime05)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmillertime05 &raquo;</TD></TR><TR><TD CLASS="quote">hey man just use your stock ones from your old manifold. i have skunk 2 and used mine from my gsr manifold just screw out and screw in and you're done. and yeah you should be able to use your same gasket...i did </TD></TR></TABLE>
Really? I just thought they were stuck in there.
Old Feb 15, 2007 | 02:55 PM
imacoolkid's Avatar
yeah im pretty sure. double check me but i just took some vise grips and unscrewed them no prob. just try it and also your throttle body ones are the same way
Old Feb 15, 2007 | 03:30 PM
boomersz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmillertime05 &raquo;</TD></TR><TR><TD CLASS="quote">yeah im pretty sure. double check me but i just took some vise grips and unscrewed them no prob. just try it and also your throttle body ones are the same way </TD></TR></TABLE>
i already got new ones for the tb anyways. i'll try later today
Old Feb 15, 2007 | 03:59 PM
boomersz's Avatar
Haha got em off
Old Feb 15, 2007 | 05:23 PM
1badteg's Avatar
all the sensors and fuel rail studs. while your at it get a password jdm intake manifold gasket and new studs/bolts for the IM. g'luck
Old Feb 15, 2007 | 07:46 PM
boomersz's Avatar
Default Re: (1badteg)
Ok here's what i got so far...
What do I do about the EVAP off the old IM?
Old Feb 15, 2007 | 07:53 PM
imacoolkid's Avatar
Default Re: (zoo)
looks good to me man.... you can ditch that canister i do believe im almost 100% sure i did
Old Feb 15, 2007 | 08:07 PM
boomersz's Avatar
Default Re: (cmillertime05)
so that's it?
Old Feb 15, 2007 | 08:10 PM
imacoolkid's Avatar
Default Re: (zoo)
well im a lil tired its been a long, rough day but from what i see it looks ready to me
Old Feb 15, 2007 | 08:28 PM
boomersz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmillertime05 &raquo;</TD></TR><TR><TD CLASS="quote">well im a lil tired its been a long, rough day but from what i see it looks ready to me </TD></TR></TABLE>
haha alright
Old Feb 16, 2007 | 03:38 AM
mac_24_seven's Avatar
Default Re: (zoo)
So you've got some tuning lined up right? Cause your gonna lose some power w/no runner crossover...
Old Feb 16, 2007 | 09:19 AM
boomersz's Avatar
chipped ecu with my mods for now, going to be turboed later so getting things ahead.
Old Feb 16, 2007 | 05:36 PM
boomersz's Avatar
Default Re: (zoo)
anyone else?
Old Feb 17, 2007 | 06:37 AM
boomersz's Avatar
bump...
Old Feb 19, 2007 | 09:10 PM
boomersz's Avatar
Old Feb 19, 2007 | 09:25 PM
B series FTW's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoo &raquo;</TD></TR><TR><TD CLASS="quote">
Really? I just thought they were stuck in there.</TD></TR></TABLE>
same.
Old Feb 20, 2007 | 07:51 AM
boomersz's Avatar
Default Re: BLOX IM, what bolts/studs do I need? (B series FTW)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoo &raquo;</TD></TR><TR><TD CLASS="quote">what do i do about the EVAP solenoid and vaccum? i don't think my swap came with one or if it was supposed to, 94 gsr</TD></TR></TABLE>
Old Feb 20, 2007 | 12:05 PM
boomersz's Avatar
bump
AnonymousHatch
Jun 12, 2018 08:56 PM
boomersz
Feb 17, 2007 02:25 PM
Drizzo
Sep 28, 2006 01:47 PM
import810
Jun 7, 2006 12:04 PM
85mm LS VTEC
Sep 1, 2005 06:20 PM
