lots of ???? about h22a motor
Old Feb 15, 2007 | 12:03 PM
ohio_twin_ser's Avatar
Default lots of ???? about h22a motor
first off i was wondering if any one could tell me the compression ration of an h22a????? i plan to put this into a 94 hatch.... and boast it... also can any one tell me what is the safest amount of boast i can run through the motor??? without doing internals... and finally what type of transmissions do u guys have on ur motors..? im not sure if u can swap them out like the d and b series motors... kinda new to the h series... i would appricate any help... thank a lot...
Old Feb 15, 2007 | 12:09 PM
thegeorge613's Avatar
Default Re: lots of ???? about h22a motor (ohio_twin_ser)
Compression is 10:1 IIRC. For boost, 10 psi is already pushing it, due to the weak ringlands of the H-series engines in general. You need a heck of a tuner for 10 psi. Something around 6-8 psi is okay for stock internals.
If I remember correctly, F-series trannys and H-series trannys are interchangeable.
All this stuff is in the FAQs link at the top of the page.
Old Feb 15, 2007 | 12:13 PM
VTecLude1994's Avatar
Default Re: lots of ???? about h22a motor (thegeorge613)
USDM 10.4:1
JDM 10.6:1
Blue Top JDM 11:1
10psi not even a good tuner could accomplish. I think 8psi is pushing it even with a spot on tune.
Old Feb 15, 2007 | 12:21 PM
ninja 6's Avatar
Default Re: lots of ???? about h22a motor (VTecLude1994)
lol "boast"
"stop boasting about your boast!"
na>boast
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thegeorge613 &raquo;</TD></TR><TR><TD CLASS="quote">
correct.
Old Feb 15, 2007 | 12:35 PM
so would u suggest changing the transmission out??? to an f-series???
Old Feb 15, 2007 | 12:41 PM
ninja 6's Avatar
depends on how long you like your gears.
you say you're "boasting"....so i assume you want a long geared tranny...in that case an h23 or an f22 trans will be good. the f22 might be a little too long. md23vtec used an h23 tranny on his turbo beast. pm his ***.
but yeah, that's kind of cut and dry basics. do more research dude.
Old Feb 15, 2007 | 12:48 PM
thanks for the info guys .... sorry didn't wanna sound retarded or anything but im not gonna lie i dont know **** about the h-series... just thougth i would see how it would work out in my hatch...
Old Feb 15, 2007 | 12:57 PM
ludeDVR's Avatar
USDM h22's are 10:1 CR, not 10.4:1.
Regular JDM h22's are 10.6:1.
Type S and SiR S-Spec's are 11:1
Old Feb 15, 2007 | 02:47 PM
Chuckles99SH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ohio_twin_ser &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the info guys .... sorry didn't wanna sound retarded or anything but im not gonna lie i dont know **** about the h-series... just thougth i would see how it would work out in my hatch...</TD></TR></TABLE>
That being said, visit the forced induction section of the forum and start reading, search search search, then search some more.
Old Feb 15, 2007 | 03:47 PM
DJsilkyjr's Avatar
10psi should be fine on a stock motor as long as u have a good tune
Old Feb 15, 2007 | 05:08 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTecLude1994 &raquo;</TD></TR><TR><TD CLASS="quote">USDM 10.4:1
JDM 10.6:1
Blue Top JDM 11:1
10psi not even a good tuner could accomplish. I think 8psi is pushing it even with a spot on tune.</TD></TR></TABLE>
haha I highly disagree. well depending if its basic greddy, fmax, drag t3/t4 kit. I have seen upwards of 14 psi. Not saying its the safest thing but it definatly can work .
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ap &raquo;</TD></TR><TR><TD CLASS="quote">depends on how long you like your gears.
but yeah, that's kind of cut and dry basics. do more research dude.</TD></TR></TABLE>
Never heard of him
Old Feb 15, 2007 | 07:20 PM
prelittlelude's Avatar
JDM 10.6:1
Blue Top JDM 11:1
don't be such a women, i have been boosting 11psi on stock honda pistons at 9:! c/r for 2 years. everything is A-ok
Old Feb 15, 2007 | 11:32 PM
Dr. Willy's Avatar
Default Re: lots of ???? about h22a motor (prelittlelude)
i dont feel like starting a new thread for this cause its a simple question, but while we are on the subject of h22 internals, im buying an h22a4 block off a friend for cheap, just needs new pistons. Im just gonna put stock pistons back in it for now till i save up enough money for the boast i wanna run, but do all non-pistons from 92-00 work?
Old Feb 16, 2007 | 04:03 PM
md23vtec's Avatar
Default Re: lots of ???? about h22a motor (Dr. *****)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. ***** &raquo;</TD></TR><TR><TD CLASS="quote">i dont feel like starting a new thread for this cause its a simple question, but while we are on the subject of h22 internals, im buying an h22a4 block off a friend for cheap, just needs new pistons. Im just gonna put stock pistons back in it for now till i save up enough money for the boast i wanna run, but do all <U>non-pistons</U> from 92-00 work?</TD></TR></TABLE>
Non pistons? Can you be more clear so we can give you an answer
Old Feb 16, 2007 | 07:07 PM
AndrePerras's Avatar
Default Re: lots of ???? about h22a motor (md23vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by md23vtec &raquo;</TD></TR><TR><TD CLASS="quote">Non pistons? Can you be more clear so we can give you an answer </TD></TR></TABLE>
He wants a rotary engine.
Old Feb 17, 2007 | 08:06 AM
Dr. Willy's Avatar
whoops i meant non type s pistons, guess what i get for typing when im outta it.
v99h22
Apr 18, 2013 06:34 AM
Inside the Torn
15
Sep 15, 2005 07:09 AM
b.serious
Jul 22, 2005 03:54 PM
gerhard
Apr 20, 2005 06:46 AM
kc690
Dec 5, 2002 07:37 PM
