4th gen oil light blinking
^^Yeah, oils low most likely..
Mine will blink when my is. Or if it is slightly low and I come to a hard stop it'll start then...
Check your oil level, and add some if it's low before ya burn something up!
Check the oil, maybe if your car is on a hill or it's not leveled it might come on, like when I'm low on gas and the car is not leveled the light comes on, but as soon as it's leveled again it goes off
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by extracrunchie »</TD></TR><TR><TD CLASS="quote">so what if its low pressure? wahts teh fix for that?</TD></TR></TABLE>
a new oil pump
a new oil pump
My oil light blinked the other day. I had just got it back from a rear main seal job, and they either filled it really low (after telling me they filled it up) or it lost 2.5 quarts in 2 days (wasn't fixed).
Anyway, it ended up being low oil level. Wait a while after you have run your car, wipe off the dipstick, stick it back in, and make sure its close to the top hole.
the oil light means really low oil pressure, it means the same thing on every car. when youre low on oil and brake or turn hard and it flashes, that means the oil pickup isnt getting oil cuz theres not enough in the pan. if yours is flashing all the time even though the oil is full, its time for an oil pump. if youve been driving it like this and your motor hasnt taken a ****, check the oil pressure sending unit
1 Cam Wonder
44
Nov 23, 2004 08:18 AM
