bent valves
i bent 8 valves in the engine of my type r... is this a massive job to fix.. i have the head off i can can see which valves are bent... is it a big job from where i am to finish it..
Get a Helm manuel. Take out cam, valvespring, then head. Replace the bent valve. Get a new head gasket and some hondabond. Put everything back together and torque it to spec.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soeurm »</TD></TR><TR><TD CLASS="quote">Get a Helm manuel. Take out cam, valvespring, then head. Replace the bent valve. Get a new head gasket and some hondabond. Put everything back together and torque it to spec.</TD></TR></TABLE>
That and stop powershifting
Dude, take it off and send it to someone who rebuild heads for a living.
Other things could have happened that you may not see. Again MO.
Its an R, not an 89 civic DX. Think about it.
you can only see certain valves that are bent, how about the ones that are so little bent that you don't know until you do a compression test? how about valve guides, are they alright? take it to a machine shop who knows hondas and have them do it. There is a saying at the honda dealership I work at that goes "So you have time to do it twice but not enough time to do it right?"
what's the hondabond for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tewee »</TD></TR><TR><TD CLASS="quote">
what's the hondabond for?</TD></TR></TABLE>
Gasket Sealer. Do a search on it.
oh boy. you guys are scary....<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soeurm »</TD></TR><TR><TD CLASS="quote">Get a Helm manuel. Take out cam, valvespring, then head. Replace the bent valve. Get a new head gasket and some hondabond. Put everything back together and torque it to spec.</TD></TR></TABLE>
he's got the head off. so the cams are already out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rcar97 »</TD></TR><TR><TD CLASS="quote">Dude, take it off and send it to someone who rebuild heads for a living.
Its an R, not an 89 civic DX. Think about it.</TD></TR></TABLE>
what makes it so special cause its an "R?" its a cylinder head just like any other. yea, you should send it out to have it checked (maybe bent the other 8, maybe damaged valve guides) but slapping new valves and lapping them in won't hurt anything.
smacks forehead.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lo-Buck EF »</TD></TR><TR><TD CLASS="quote">oh boy. you guys are scary....
smacks forehead.....</TD></TR></TABLE>
this is worse than me...
take the head to a shop have new guides and valves installed a,djust put it back on. dont expletive up the timming belt install like i did
goo_punch
Nov 1, 2015 02:54 PM
DJYoshaBYD
Dec 9, 2009 10:59 AM
jyacoba2009
Nov 23, 2009 08:25 PM
Y2KGreenGSR
Nov 1, 2002 06:03 PM
