quick compression question (GSR)
just wanted to know the factory GSR b18's compression (psi and ratio) and what would the psi be if I'd chose to go with 9.0.1 J/E pistons? that's it. thanks for the help guys.
c-speedracing.com is where its at. According to AllData:
COMPRESSION AT 250 RPM AND WIDE OPEN THROTTLE:
Nominal 1860 kPa (270 psi)
Minimum 930 kPa (135 psi)
Maximum Variation 200 kPa (28 psi)
pettyboy69
Jun 22, 2009 07:39 AM
