Pulled off the head, how do my pistons look?
Old Feb 14, 2007 | 04:53 PM
boomersz's Avatar
Default Pulled off the head, how do my pistons look?
Soo how does it look? The stuff on the pistons wipe off pretty easily but I left it for the pictures...also motor has been sitting for awhile, is there anything I need to do before putting it back together?
Just click the thumbnails.
Flash made things look worse, but everything wipes off, not sure what it is though.
Modified by zoo at 11:25 PM 2/14/2007
Old Feb 14, 2007 | 05:07 PM
Folgers's Avatar
Default Re: Pulled off the head, how do my pistons look? (zoo)
Looks fine to me, pretty sure thats just carbon.
Old Feb 14, 2007 | 05:09 PM
CubanLynx84's Avatar
from those last 2 pics it looks like you might have to bore or hone the walls a bit and go with oversized rings. I could be wrong. Just to me the cylinder walls look too scratched up.
Old Feb 14, 2007 | 05:18 PM
qwk db8's Avatar
ur pics are to small i got stigmitizims
Old Feb 14, 2007 | 05:20 PM
-Championship-'s Avatar
76.169.175.137
Default Re: Pulled off the head, how do my pistons look? (CubanLynx84)
hone the wall?....you most deff must hone it if putting new rings and/or pistons
so whats going to be the setup?
Old Feb 14, 2007 | 05:45 PM
JoePSI's Avatar
Default Re: Pulled off the head, how do my pistons look? (CW_98gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CubanLynx84 &raquo;</TD></TR><TR><TD CLASS="quote">from those last 2 pics it looks like you might have to bore or hone the walls a bit and go with oversized rings. I could be wrong. Just to me the cylinder walls look too scratched up.</TD></TR></TABLE>
Only if he was rebuilding it. They are not in terrible shape. Since you have the motor out and apart you do need to bore it to at least .5mm over.
Old Feb 14, 2007 | 06:39 PM
GsrIntegra789's Avatar
Default Re: Pulled off the head, how do my pistons look? (JoePSI)
is it just me or does it look like that motor hasnt ran for a while. Also the walls are a bit glazed. Honeing it will fix the prob.
Old Feb 14, 2007 | 06:53 PM
boomersz's Avatar
Default Re: Pulled off the head, how do my pistons look? (GsrIntegra789)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrIntegra789 &raquo;</TD></TR><TR><TD CLASS="quote">is it just me or does it look like that motor hasnt ran for a while. Also the walls are a bit glazed. Honeing it will fix the prob. </TD></TR></TABLE>
It hasn't. Been sitting for little while.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CW_98gsr &raquo;</TD></TR><TR><TD CLASS="quote">hone the wall?....you most deff must hone it if putting new rings and/or pistons
so whats going to be the setup?</TD></TR></TABLE>
Just wanted to know how they are, not building it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qwk db8 &raquo;</TD></TR><TR><TD CLASS="quote">ur pics are to small i got stigmitizims </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zoo &raquo;</TD></TR><TR><TD CLASS="quote">Soo how does it look? The stuff on the pistons wipe off pretty easily but I left it for the pictures...
<FONT SIZE="5">Just click the thumbnails.</FONT>
Old Feb 14, 2007 | 07:29 PM
boomersz's Avatar
Would there be anything wrong with running the motor how it is now? And what should I use to clean up the walls/pistons?
Old Feb 14, 2007 | 07:38 PM
Jay J's Avatar
Prince of Zamunda
Default Re: (zoo)
Seafoam to kill the carbon
Old Feb 14, 2007 | 07:52 PM
boomersz's Avatar
so just leave it as is now and run sea foam after everythings together?
93Eh6pWr
Jul 20, 2010 03:43 PM
mRvYbEs
Oct 17, 2007 09:49 PM
boomersz
Feb 15, 2007 12:29 PM
94B18B1Teg
Jan 26, 2004 01:20 PM
