B18C5 / ITR motor in an EK...throttle cable?
Old Feb 14, 2007 | 04:05 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default B18C5 / ITR motor in an EK...throttle cable?
I currently have a 97 civic coupe with a GSR swap. I'm using a GSR throttle cable and bracket that my buddy lent me. I'm pulling the swap for a 98 ITR motor, which has the throttle cable bracket attached to the ITR intake manifold.
Do I HAVE to use the ITR throttle cable, or can I run a B16 or LS throttle cable on an ITR EK?
Old Feb 14, 2007 | 06:44 PM
BJOnewiper's Avatar
Default Re: B18C5 / ITR motor in an EK...throttle cable? (boostincoupe)
You should be able to reuse it or may need only to change the throttle cable bracket.
Old Feb 14, 2007 | 07:34 PM
Default Re: B18C5 / ITR motor in an EK...throttle cable? (BJO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BJO &raquo;</TD></TR><TR><TD CLASS="quote">You should be able to reuse it or may need only to change the throttle cable bracket.</TD></TR></TABLE>
Did you read the thread? I don't have a throttle cable, and I'm wondering if I NEED to buy an ITR throttle cable, or if a B16 or LS throttle cable would work.
Old Feb 14, 2007 | 07:37 PM
BJOnewiper's Avatar
The cable will work so long as the bracket is moved a bit. I had a shop ghetto fab one for me.
Old Feb 17, 2007 | 04:41 PM
twotonecivic's Avatar
i ghetto fabbed my own t/c bracket. no biggie.
k20o2o4civic
Mar 3, 2009 07:22 PM
bleakdragonmage
Feb 25, 2007 10:40 AM
timisyourfriend
Nov 12, 2006 12:29 PM
g_rant2006
Aug 27, 2006 08:27 PM
CNSK
Aug 4, 2004 06:29 AM
