H22A Euro-R rocker arms
Old Feb 14, 2007 | 02:13 PM
cpmike's Avatar
Default H22A Euro-R rocker arms
have a couple rocker arms with too much wear, so i need 2 new rocker arm assy's.
the obd2 H22A Euro-R head (PDE code) is most similar to an H22A4, correct? rocker arm assys for H22A1 and H22A4 are different prices and part numbers, not sure what the difference is and which style the Euro-R used, so im not sure which to get.
ill be getting them from the dealer (hondaautomotiveparts.com), assuming theres no other cheaper source for OEM rockers, unless i find somebody parting out a head (i wish)
thanks for any help.
Old Feb 15, 2007 | 05:18 AM
cpmike's Avatar
Default Re: H22A Euro-R rocker arms (cpmike)
so.... yea
Old Feb 15, 2007 | 01:31 PM
George Knighton's Avatar
H-T Order of Merit
Moved to Prelude at Bense's request, so the guy could get some help.
Old Feb 15, 2007 | 01:37 PM
Mykizism's Avatar
ive used obd1 h22a rocker arms in a obd2 h22a4 head, so if you can find a used h22 head somewhere that might work out for you..
Old Feb 15, 2007 | 03:38 PM
cpmike's Avatar
Default Re: H22A Euro-R rocker arms (Mykizism)
much appreciated!
now that makes me wonder why honda charges $40 extra for the a1 rockers.
that aside, Type-S and Euro-R shared similar internals, including cam profiles - ive read the thread about using type-s cams in a P13 head a while ago but cant find it, but now my concern is with wear related to having euro-r (basically type-s) cams with p13 rockers.
anyhoo ill of course measure and compare (ill have my machinist get more precise if need be) before installation. i tracked down a local set of H22A4 rockers that i will be comparing mine to, and if they match, i would assume i could pick from any H22 rockers.
Old Feb 15, 2007 | 06:51 PM
Rosko's Avatar
I have a whole box of extra rockers, PM me if all else fails and you still need them.
Old Mar 7, 2007 | 05:49 AM
cpmike's Avatar
for future reference, H22A Euro-R rocker arms are identical to H22A4 rocker arms (which should also be the same as those from an H22A1)
mozzandherb
Jun 22, 2011 07:55 AM
SiRTifiedacc
Jul 27, 2006 07:38 PM
DevineCRX
Jul 23, 2002 06:59 PM
