I need custom speedometer options
The car I have has NO provisions for a gear driven vehicle speed sensor...so i need something custom to attach to a wheel or something for a signal but i dont even know if such a product is out there...need suggestions...thanks...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Str8 outta Cliff »</TD></TR><TR><TD CLASS="quote">does anyone know what would be needed to use one of the abs wheel speed sensors to provide a vss signal to an obd1 ecu?</TD></TR></TABLE>
The wheel speed sensors are VR sensors while the VSS is a hall sensor I believe. You need a way to convert a sinusoidal wave into a square wave. Autronic makes a box to do this for crank angle sensors but you need to get the number of pulses/mile correct. You'll probably have to grind some teeth off of the reluctor ring but it shouldn't be a huge project to do.
ColeCooper90
Jan 4, 2019 12:35 PM
woszczy
Jun 3, 2012 08:05 PM
