anyone made their own balance shaft removal kit??
Old Feb 14, 2007 | 05:41 AM
bluedlude's Avatar
Default anyone made their own balance shaft removal kit??
so ive got this oil pump sitting here. the block ive got already has the balance shafts removed from it so im not about to replace them, and i was thinking, how hard can it be to close everything off. just wondering if anyone has done this, or attempted to. ive got access to a CNC and a lathe, and the only material i would have to buy would be a small sheet of aluminum. and ive been learning about press fits in one of my classes so i could actually engineer the press fit plug. just wondering if anyone has tried this yet?
Old Feb 14, 2007 | 05:58 AM
4WSi_guy's Avatar
Default Re: anyone made their own balance shaft removal kit?? (bluedlude)
https://honda-tech.com/zerothread?id=1278213
thats just one...theres tons of threads about BS removal.
Old Feb 14, 2007 | 05:59 AM
PirateMcFred's Avatar
Press fits are easy. Make it .001" oversize, degrease and install using Loctite 603.
Hell you could RTV everything over instead of machining anything. The bigger concern is rotating all the BS bearings 90˚ to cut off oil to unused orifices to keep your oil pressure. It a lot of work to lose 8 pounds and gain 3hp though.
Pirate
Old Feb 14, 2007 | 06:06 AM
bluedlude's Avatar
Default Re: anyone made their own balance shaft removal kit?? (PirateMcFred)
well i figure itll take all of 20mins on the lathe to make the plug. about 40mins to make the cover plate thing out of the sheet and drill holes. and as far as the orifices, i was going to plug those somehow or another. i havent looked into the best way to do that, but i guess since i know im never going to put them back in i could have someone drop a bead of weld if i remove the bearings. **** even some A/B epoxy might work?
Old Feb 14, 2007 | 06:23 AM
It'd be a tight fit to get in there with a stinger to weld them. I would steer away fro JB Weld though. Do whatever. It's still a lot of work for minimal gains. If you have upgraded mounts the added vibration is annoying too. Just my opinion though.
Pirate
Old Feb 14, 2007 | 07:34 AM
98vtec's Avatar
moderator emeritus
wussy.
Old Feb 14, 2007 | 07:36 AM
Mykizism's Avatar
lol, for some reason im the only one who thinks my motor vibrates less with the balance shafts removed!
maybe i just built my motor better than honda did
Old Feb 14, 2007 | 08:23 AM
bluedlude's Avatar
Default Re: (Mykizism)
how well is your setup balanced?
Old Feb 14, 2007 | 09:10 AM
Mykizism's Avatar
Default Re: (bluedlude)
shrugs.. lol
the crank was sent to benson and was balanced and micro polished
the rods and pistons, were all balanced as well
thats about it..
Old Aug 16, 2007 | 06:25 PM
EGHATCH4YA209's Avatar
i've made some block off plates for the one big cover on a cnc machine, als got an easy plug for the other side thats actualy with a rubber seal that works flawless, then i've had 4 dowel pins made thae block off all the oil passages that you need to , its just like keizen speeds but its a whold lot cheaper, if your interested let me know i can sell you one for $65 pluss shipping, ill pust pics for you soon, im still gouin to modify my origional block off plates a lil but i still have a bunch of the ones i already made
Old Aug 16, 2007 | 06:59 PM
98vtec's Avatar
moderator emeritus
Default Re: anyone made their own balance shaft removal kit?? (EGHATCH4YA209)
jacob,
talk to rosko.
Old Aug 17, 2007 | 05:14 AM
Default Re: anyone made their own balance shaft removal kit?? (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">wussy.</TD></TR></TABLE>
Lol. It took me a while to notice that remark, Blake.
I have one car that vibrates just fine and I don't mind at all (3000 rpm will numb your nuts after a while), it's got no stereo, no AC, no heater, no windows, no sunroof, no doors, no cruise control, no power steering, and no upholsertry. I think I deserve a few ammenities in the Prelude. Besides, I've removed 250 pounds from the 'Lude. I can afford to run the balance shafts.
Pirate
Old Aug 17, 2007 | 07:16 AM
98vtec's Avatar
moderator emeritus
Old Aug 17, 2007 | 08:50 AM
hybrid2007's Avatar
Theres another way of doing it without turning your bearings. if you separate your main caps from your girdle you can make up more plugs to block the oil passages to the bearings
Old Sep 5, 2007 | 07:59 AM
SuperSlow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGHATCH4YA209 &raquo;</TD></TR><TR><TD CLASS="quote">i've made some block off plates for the one big cover on a cnc machine, als got an easy plug for the other side thats actualy with a rubber seal that works flawless, then i've had 4 dowel pins made thae block off all the oil passages that you need to , its just like keizen speeds but its a whold lot cheaper, if your interested let me know i can sell you one for $65 pluss shipping, ill pust pics for you soon, im still gouin to modify my origional block off plates a lil but i still have a bunch of the ones i already made </TD></TR></TABLE>How can you be contacted? Have pics?
Old Sep 26, 2007 | 02:11 PM
Default Re: anyone made their own balance shaft removal kit?? (SuperSlow)
i will post some pics up for you asap, the kit will sell for $65 shipped. we will be posting them for sale within a week or so, if your interested email me at joshuaglobal@yahoo.com and ill send you some pics asap.
Old Sep 27, 2007 | 12:33 AM
Demonlude's Avatar
Default Re: anyone made their own balance shaft removal kit?? (Evil.98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil.98vtec &raquo;</TD></TR><TR><TD CLASS="quote">jacob,
talk to rosko.</TD></TR></TABLE>
Old Sep 27, 2007 | 04:53 AM
mgags7's Avatar
set screws might work in the oiling holes, if you have space to get in there.
Rattles are my worst enemy, I hayt them, and having an auto-&gt;manual prelude they hate me too.
ldyer1994
Aug 25, 2015 01:51 PM
Innovation
Mar 4, 2011 07:08 AM
KleenL
Dec 27, 2007 02:17 PM
AbaZ
Jun 22, 2004 05:45 PM
ludesleep
Jul 22, 2003 07:58 PM
