Type R brakes on a 91 Civic Si
My 91 Si currently has a compete Integra RS brake swap...
15/16" Master Cylinder
4040 Prop Valve
91 EX Spindles with 10.3" rotors
94 RS trailing arms with disk brakes.
At home I have a set of Type R calipers that I'm rebuilding to install on the car with a set of 96 Prelude rotors (same rotor as Type R but with proper center bore and 4x114 instead of 5x114) that I'm getting redrilled to 4x100.
My question is:
Is there an OEM 1" master cylinder which will bolt in to the 91 Si Booster and brake lines?
It seems like the 96 prelude did come with a 1" master, as did some 91-94 Accords. The Type R also came with a 1" master cylinder but using that unit would force a booster change as well from what I've seen. Any ideas?
4040 Prop Valve
My question is:
nefariousyellow
Dec 24, 2007 10:09 PM
