es oval w/ custom b-pipe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEj8 »</TD></TR><TR><TD CLASS="quote">It'll be fine..Match it with a header with a 2.5" collector and get it tuned and you'll be happy you did it.</TD></TR></TABLE>
im going to run a p28 ecu good enough? lol
you need to get a tune even if you dont have cams?
Ehh you should be able to squeek by..Not on a stock d16 map tho..If you have a gsr basemap you should be fine with I/H/E but if you upgrade cams you deffinately need to tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEj8 »</TD></TR><TR><TD CLASS="quote">Ehh you should be able to squeek by..Not on a stock d16 map tho..If you have a gsr basemap you should be fine with I/H/E but if you upgrade cams you deffinately need to tune.</TD></TR></TABLE>
yeah i got jdm gsr ecu I'm going to run p28 chipped in the future.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEj8 »</TD></TR><TR><TD CLASS="quote">Then you'll be fine..As long as you keep the butterflies hooked up, otherwise youll get a CEL..i think</TD></TR></TABLE>
no there won't be a CEL light i ran a churches custom ECU on my car before the butterfly just stay open the whole time and vtec hit once, but I'm going to upgrade to a blox in the future w/ the ecu.
Stefndogg
Northern California (Sales)
91
Feb 8, 2006 05:59 PM
