96 Civic Front Wheel Stud Replacement
Old Feb 13, 2007 | 04:32 PM
EKBOOSTDREAMS's Avatar
Default 96 Civic Front Wheel Stud Replacement
I have a stripped front wheel stud on my 96 hatch. I want to replace it but Im not sure if I have the right tools to do it myself. I did some searching but I pretty much just found how-to's on eg's and people arguing if you need a press to do the stud replacement on a 96 civic. My question is, do I need anything special to change my stud? Or do I just need to take the caliper and rotor off hammer the old stud out and put the new one in? Any help is appreciated.
Old Feb 14, 2007 | 11:07 AM
Default Re: 96 Civic Front Wheel Stud Replacement (EKBOOSTDREAMS)
bump, no one has done this?
Old Feb 14, 2007 | 11:34 AM
SilverCoupeEj8's Avatar
i have you need a press... it sucks trust me... the hub is in the way so you cant remove them.. and if you do... you cant put the studs on str8 because of the angle ...i took it to my friends shop and he did it for me
Old Feb 14, 2007 | 11:36 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKBOOSTDREAMS &raquo;</TD></TR><TR><TD CLASS="quote">bump, no one has done this?</TD></TR></TABLE>
it's the same process on an 5th and 6th gen civic's.
https://honda-tech.com/zerothread?id=907985
^^the link above should help.
Old Feb 14, 2007 | 11:37 AM
philosofy1's Avatar
Default Re: (SilverCoupeEj8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCoupeEj8 &raquo;</TD></TR><TR><TD CLASS="quote">i have you need a press... it sucks trust me... the hub is in the way so you cant remove them.. and if you do... you cant put the studs on str8 because of the angle ...i took it to my friends shop and he did it for me</TD></TR></TABLE>
you can doi it without a press, does suck but it can be done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKBOOSTDREAMS &raquo;</TD></TR><TR><TD CLASS="quote">I have a stripped front wheel stud on my 96 hatch. I want to replace it but Im not sure if I have the right tools to do it myself. I did some searching but I pretty much just found how-to's on eg's and people arguing if you need a press to do the stud replacement on a 96 civic. My question is, do I need anything special to change my stud? Or do I just need to take the caliper and rotor off hammer the old stud out and put the new one in? Any help is appreciated. </TD></TR></TABLE>
oh, yeah forgot to tell you, if you don't want to do this, you can always pick up a spare spindle at any salvage yard and just swap it out, that's what i did. but don't take to long on this, or your bearing will start to go bad.
Old Feb 14, 2007 | 11:45 AM
Default Re: (philosofy1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 &raquo;</TD></TR><TR><TD CLASS="quote">
oh, yeah forgot to tell you, if you don't want to do this, you can always pick up a spare spindle at any salvage yard and just swap it out, that's what i did. but don't take to long on this, or your bearing will start to go bad.</TD></TR></TABLE>
I think we are just gonna replace the stud because salvage yards around here dont have a lot of civics. Also the part is like $3 at Honda. I dont have a press but we do have a lot of tools that should help us get the stud out. Thanks for the replies.
Old Feb 14, 2007 | 12:08 PM
No problem... you dont need a press like mentioned above.. but is a pain to do... goodluck changing the stud!
Old Feb 14, 2007 | 12:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCoupeEj8 &raquo;</TD></TR><TR><TD CLASS="quote">No problem... you dont need a press like mentioned above.. but is a pain to do... goodluck changing the stud!</TD></TR></TABLE>
Thanks
Lemmingz
Jul 4, 2012 06:01 PM
jchandler
Oct 18, 2004 06:50 AM
chopper
Mar 29, 2004 01:36 PM
