B16A2 for sale
Old Feb 13, 2007 | 04:22 PM
civicliveit's Avatar
Default B16A2 for sale
I have a b16a2 from a 2000 si for sale. It is fully disassembled. The motor had a detonation problem and the 2-4 piston ringlands blew out. Block is in great shape. Have most parts to rebuild it. Missing pistons only.
parts included are :
Block
Crank
Head
OBD 1 Distributor
New Eagle Forged H beam rods
New Clevite 77 Bearings
New AEBS Headstuds
new CTR N1 Crank pully
New honda head gasket
New honda intake gasket
New honda exhaust gasket
New honda Intake Valve seals
New honda Exhaust Valve seals
New honda VTEC solonoid gaskets
New honda valve cover gasket
New honda spark plug tube seals
New honda valve cover grommets
New honda oil pan gasket
new honda oil pickup gasket
new honda o rings for water tube
new honda o ring for pcv canister
new honda o ring for distributor
new honda thermostat
new honda distributor cap
New Water pump
New timing belt
New tensioner
Prolly more stuff that im forgetting but its all little stuff. This was a great motor and only needs a set of pistons, a good cleaning, hone job and re-assembly. This motor had only 75k on it when the ringlands went. The crank is still in the block so there is no confusion about where the main caps go. This needs to go now.
$1000 obo.
I also have a P30 OBD 1 ECU for sale. $150 - I bought this new at Honda about 5 years ago for roughly 500 bucks. Never been opened up.
My email is civicliveit@yahoo.com Email me if interested as I dont frequent the forum very much anymore as to not owning a honda.
Local pick up is preferred. Located in Sioux Falls, SD
Old Feb 13, 2007 | 04:38 PM
SOHC-VTEC-BB2's Avatar
Default Re: B16A2 for sale (civicliveit)
can you ship
Old Feb 13, 2007 | 07:23 PM
Default Re: B16A2 for sale (LudeFanatic)
are you interetsed in the motor ? I could ship but it would be prolly expensive.
Old Feb 13, 2007 | 07:26 PM
ClubRX's Avatar
DO you have the tranny?
Old Feb 13, 2007 | 07:30 PM
Default Re: B16A2 for sale (ClubRX)
no, the trans was shelled out. I do have the case for the trans though. I also have all the internals from the trans but the diff. Hub slider and synchro assemblies are shot.
dustin_crxsi's Avatar
WOW!! Awesome Deal
Bump For you
Old Feb 13, 2007 | 07:31 PM
Default Re: B16A2 for sale (dustin_crxsi)
thanks for the bump
Old Feb 14, 2007 | 02:23 PM
ttt. has to go. says best offer too
Old Feb 16, 2007 | 10:14 AM
evillesi's Avatar
any pics
Old Feb 17, 2007 | 01:16 PM
Default Re: B16A2 for sale (evillesi)
i will take some pics tonight or tomorrow and post them up.
JDM94TEG
May 31, 2013 08:47 AM
SHell_
Dec 12, 2008 11:32 AM
civicliveit
Feb 17, 2007 01:14 PM
JDM_FRONTIN
Nov 15, 2005 08:55 AM
