crower camshaft vs skunk2 camshaft vs jun camshaft
Old Feb 13, 2007 | 04:11 PM
ge_itr's Avatar
Default crower camshaft vs skunk2 camshaft vs jun camshaft
planning to get a stage 2 camshaft but not sure of which one to get. does anyone know which one is better or more preferrable for all motor street/strip application? anyone compared it in performance or dynoed any of these? thanks.
Old Feb 13, 2007 | 04:13 PM
vinuneuro's Avatar
Default Re: crower camshaft vs skunk2 camshaft vs jun camshaft (ge_itr)
Jun is more expensive than the others, but every dyno with their cams I've seen has produced great numbers, and great curve.
Old Feb 13, 2007 | 04:18 PM
SOHC-VTEC-BB2's Avatar
I was just reading a thread on the Skunk 2 Pro series and they seem to be great performers.
Old Feb 13, 2007 | 04:58 PM
98vtec's Avatar
moderator emeritus
Default Re: crower camshaft vs skunk2 camshaft vs jun camshaft (vinuneuro)
fo sho, i havent driven on any of those cams before but i got JUN's going into the hybrid. From what i have read, these cams make great power and still allow the motor to idle very well. I've never read about any complaints regarding them being unstreetable or having rough idles.
Old Feb 13, 2007 | 05:03 PM
mgags7's Avatar
in my country they go crazy for the skunk2 pros, the crowers not so much....
Old Feb 13, 2007 | 05:04 PM
98vtec's Avatar
moderator emeritus
Default Re: (mgags7)
hell yea...i take it you saw the pro1's that bearsEK (iirc) posted in the all motor forum making more than damn good power, lol.
Old Feb 13, 2007 | 05:06 PM
mgags7's Avatar
nah it was vteckidd, but yea, they made incredible power
Old Feb 13, 2007 | 05:11 PM
98vtec's Avatar
moderator emeritus
ah....yes. the kidd.
yup, thats them
Old Feb 13, 2007 | 05:30 PM
MLBZ521's Avatar
Default Re: (LudeFanatic)
I've also read/seen good results for the new Skunk2 Pro Series.. This is what I'll be getting for my build most likely. Defiantly a for them.. Same for Jun always a good Cam, if you can find 'em. But Jun only has one cam for the H22, no stages. (Unless they changed in the last 6 months..)
Old Feb 13, 2007 | 05:43 PM
snzh22's Avatar
Default Re: (MLBZ521)
does anyone have the graph? the graph isnt showing anymore due to bandwidth
Old Feb 13, 2007 | 06:15 PM
alterdcreations's Avatar
Default Re: (snzh22)
i am going with the pro 2's in the summer
juns are also great
crowers are only good for custom grinds ... might go for those
alot cheaper
Modified by alterdcreations at 6:23 AM 2/15/2007
Old Feb 13, 2007 | 06:17 PM
ge_itr's Avatar
from what i've heard the skunk2 has rough idle when stopping. it's not really good for traffic. is this true? i know it makes good power though.
Old Feb 13, 2007 | 06:18 PM
ge_itr's Avatar
Default Re: (98vtec)
which cam is this?
Old Feb 14, 2007 | 10:34 AM
ge_itr's Avatar
so does anyone know if the jun will make more power or the pro 2?
Old Feb 14, 2007 | 11:16 AM
UK_Luder's Avatar
Default Re: (ge_itr)
Skunk2 Pro 2's are going in my build next week. I'll post up the results after the build
Old Feb 14, 2007 | 11:38 AM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_itr &raquo;</TD></TR><TR><TD CLASS="quote">so does anyone know if the jun will make more power or the pro 2?</TD></TR></TABLE>
depends on the setup (bore, stroke, compression...etc)
JUN might be better on one setup and the PRO2 might be better on another. You are supposed to build a performance motor around the cams considering they are what determine how much the valve opens and how long it remains open.
Old Feb 14, 2007 | 12:36 PM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
This isn't said nearly enough.
Old Feb 14, 2007 | 02:20 PM
ge_itr's Avatar
this is my setup up. h22. 89mm bore. 95mm stroke. 12.0:1 cr. port/polish. angle valve job. standard size valves. dual springs. tit retainers. port match IM.
skunk2 s2 or pro2 or jun camshaft? planning to get skunk2 sprockets.
Old Feb 14, 2007 | 07:13 PM
98vtec's Avatar
moderator emeritus
imo, thats because most people could careless how an engine works and dont really care to learn. They just wanna go faster.
Old Feb 14, 2007 | 08:08 PM
1GPlusSH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">imo, thats because most people could careless how an engine works and dont really care to learn. They just wanna go faster. </TD></TR></TABLE>
FASTER! Here here.
I like the price and performance of the skunk2 pro series. I'm probably going with those.
Old Feb 14, 2007 | 10:27 PM
mgags7's Avatar
This is retarded, you have no way of knowing, and neither do we. Try it.
Old Feb 14, 2007 | 10:28 PM
P13_mein's Avatar
Default Re: (1GPlusSH)
none of these are just "drop in" cams; the rest of the head & valvetrain needs similar upgrading. they both sell a package.
but the JUN has By far the best idle to high lobe lift out of the choices.
Old Feb 14, 2007 | 10:32 PM
mgags7's Avatar
Default Re: (P13_mein)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P13_mein &raquo;</TD></TR><TR><TD CLASS="quote">none of these are just "drop in" cams; the rest of the head & valvetrain needs similar upgrading. they both sell a package.
best is a pretty subjective word, you care to explain yourself?
Old Feb 15, 2007 | 07:28 PM
P13_mein's Avatar
"Best" operates with one subject in relation to others which it being compared.
in terms of smoothness of the idle and low end characteristics relative to performance increase of the high lobe.
some may prefer an extreme lift and sacrifice it for a rough idle, thus, this would not apply.
