hey! your lights are on!!!
Old Feb 13, 2007 | 02:50 PM
VTEC_PRODUCTION's Avatar
Default hey! your lights are on!!!
i would like to know if anyone knows how to hook up your parking lights so that they are on when you turn on the ignition. if anyone could tell me how you can hook these up for the easiest and cleanest way i would really appreciate it.
Old Feb 13, 2007 | 03:08 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: hey! your lights are on!!! (Acura_Integra_Type_R)
By "on", do you mean the same as when the switch is on or do you mean only the front parking lights?
Old Feb 13, 2007 | 04:38 PM
Default Re: hey! your lights are on!!! (Dogginator)
just the front parking lights...
Old Feb 13, 2007 | 04:46 PM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acura_Integra_Type_R &raquo;</TD></TR><TR><TD CLASS="quote">just the front parking lights...</TD></TR></TABLE>
Go down to Pep Boys or Radio Shack and buy an automotive relay, some wire, and a few connectors and using the ignition hot wire on the fuse box, splice into the parking lights. Obviously, the relay needs to handle the draw of the bulbs you intend to run, and the wire size should be chosen accordingly.
Not trying to be rude, but honestly, if you couldn't have done that on your own, then perhaps you should leave the electrical stuff to others. There's a lot of potential to seriously screw things up playing with the electrical systems. However, once you have the basic knowledge covered, then its all pretty much the same.
Old Feb 13, 2007 | 05:00 PM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: hey! your lights are on!!! (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">Not trying to be rude, but honestly, if you couldn't have done that on your own, then perhaps you should leave the electrical stuff to others. There's a lot of potential to seriously screw things up playing with the electrical systems. However, once you have the basic knowledge covered, then its all pretty much the same.</TD></TR></TABLE>
You don't really want to expletive around with your electrical components unless you have decent experience. It can also lead to blown fuses that will boggle your mind.
Old Feb 13, 2007 | 05:21 PM
Dogginator's Avatar
Daisy... Daisy...
You would need the above mentioned relay and diodes to prevent the front parking lights from back feeding current to all of the parking lights.
Old Feb 24, 2007 | 05:39 AM
bseries_ben's Avatar
why don't you just turn the switch???
Old Feb 25, 2007 | 12:05 AM
hindsonher's Avatar
Default Re: hey! your lights are on!!! (clover99b18c1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clover99b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">why don't you just turn the switch??? </TD></TR></TABLE>
x2 yeah
Old Feb 25, 2007 | 05:12 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hindsonher &raquo;</TD></TR><TR><TD CLASS="quote">
x2 yeah</TD></TR></TABLE>
Because some people want to customize their cars. Have you seen the Corvette lights?
Old Feb 25, 2007 | 06:36 AM
yes. but there's already a switch. i just don't understand. this isn't a customization. this is a feature already presented to you with a switch.
Old Feb 25, 2007 | 06:40 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clover99b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">yes. but there's already a switch. i just don't understand. this isn't a customization. this is a feature already presented to you with a switch.</TD></TR></TABLE>
He only wants the front parking lights to illuminate. You cannot do that with the switch. You need to add diodes to prevent the backfeed of current to the rear parking lights to achieve this.
Old Feb 25, 2007 | 06:45 AM
oh. well right on. whatever do what you want. doesn't make sense to me, but to each his own.
Old Feb 25, 2007 | 06:53 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clover99b18c1 &raquo;</TD></TR><TR><TD CLASS="quote">oh. well right on. whatever do what you want. doesn't make sense to me, but to each his own. </TD></TR></TABLE>
Trust me, my lights work normally via the combination switch. The OP simply asked for help for customization.
wreckeddc4
Jul 20, 2007 07:26 PM
racehesh
11
Jul 15, 2007 07:36 PM
Azxster
Audio / Security / Video
Apr 20, 2007 06:38 PM
chahsiubow
Nov 14, 2006 07:08 AM
Francesco
Honda S2000
13
May 31, 2006 03:16 PM
