fuel pump problems!!!!!!!!!!!!!!!!!!!!!!!!!!!!
i just did a d16z6 swap on my 88 civic std and my motor is not getting no fuel and when i put a switch on the pump to see if it turns on it still does not turn on what is wrong?
Your wiring skills suck, or the pump is shot. Make sure when testing the pump that you have a confirmed constant source of voltage, and that the pump is grounded properly (which I believe should be accomplished through it's mounting configuration anyway)
94delsol6428
Dec 27, 2006 07:06 PM
ill phil
Apr 23, 2003 11:58 PM
