Fuel injector issue: plastic tip cracked, injector bad?
Old Feb 13, 2007 | 10:29 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Fuel injector issue: plastic tip cracked, injector bad?
I remember seeing this either on here or thezcr but I can't remember exactly. I just bought some new OEM fuel injectors (PM7) and when I received them, two of them had the plastic on the end cracked and or broken. Is this going to affect the performance of the injectors? I swore I heard that they were just protective pieces in case they were dropped, etc. Any feedback is appreciated.
Old Feb 13, 2007 | 10:53 AM
89efDUSTY's Avatar
Default Re: Fuel injector issue: plastic tip cracked, injector bad? (wiZCo)
I dont think it willl effect the performance...i have the same thing. You are talking about the surrounding part around the nozzle right?
Old Feb 13, 2007 | 11:35 AM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Fuel injector issue: plastic tip cracked, injector bad? (89efDUSTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89efDUSTY &raquo;</TD></TR><TR><TD CLASS="quote">I dont think it willl effect the performance...i have the same thing. You are talking about the surrounding part around the nozzle right? </TD></TR></TABLE>
Yeah, not the nozzle itself. I actually was reading around a little more and it seems that this is OK as long as I don't knock the injector tip into anything.
Old Feb 13, 2007 | 12:51 PM
chimaira989's Avatar
Pintle cap. Do you have anyone local that rebuilds injectors? They could sell you replacements for very cheap.
Old Feb 13, 2007 | 12:52 PM
Got_soy's Avatar
Default Re: Fuel injector issue: plastic tip cracked, injector bad? (chimaira989)
it just to protect them, its fine without the caps
90Rexx
Dec 1, 2008 06:08 AM
ilikehonda
Mar 15, 2008 02:36 PM
crj_lll
Mar 30, 2006 09:42 AM
Louie_EM1
12
Feb 29, 2004 09:34 AM
