Need help on a part
Ok, I am running into a real problem with my rear brake swap. It appears that some how the cam bolts are completely seased in the knuckle on the rear drums. I mean I have tried EVERYTHING to get them off and it is just not happening. I have the lower trailing arms from the EP3 that came with my swap. What I would like to do is just drop the ones off of the EM2 rear drums and all and use the EP3 trailing arms. They come up as two different part #s but I am not sure that they are. If so would they work?? I mean when you do a 5 lug swap you use the trailing arms from the type S correct?? So I would think that me using the EP3 would be no different. Any help would be appreciated.
specialized108
21
Nov 7, 2008 04:44 PM
xoutlawz00x
Sep 15, 2005 03:42 PM
