just bought crx rough idle cant keep highway speeds
Old Feb 12, 2007 | 05:53 PM
crxfornow2's Avatar
Default just bought crx rough idle cant keep highway speeds
hello everyone tonight i picked up a 1990 crx dx with 80k original miles. this thing has a slightly rough idle but the bad part is it cant keep up on the highway acceleration is almost non existant, my old geo metro was alot quicker, thers got to be something wrong it wouldent go up hills on the highway faster than 45 miles per hour and would never rev about 4.5k even if i shifted into second going 45 there is something wrong with it im thinking that it may be running on 3 cylinders, my camaro when it was running on 6 out of 8 was still running better then this one is but the symtoms were similar any suggestions? thank you for your help im willing to spend some money on this car seeing as it only has 80k it shoud go another 120k atleast, o ya the guy i got it from said it sat for 6 months but ran fine befor that, so tommorrow im going to get new spark plugs and wires and see if that helps any
Modified by crxfornow2 at 7:05 PM 2/12/2007
Old Feb 12, 2007 | 06:05 PM
2camvtec's Avatar
Default Re: just bought crx rough idle cant keep highway speeds (crxfornow2)
Yes it sounds like plugs and wires. Make sure the gap on the plugs are 1.0 mm. Also would be a good idea to clean your injectors.
Old Feb 12, 2007 | 06:06 PM
crxfornow2's Avatar
Default Re: just bought crx rough idle cant keep highway speeds (2camvtec)
clean my injectors how do i do that? sorry but im coming off my carbed camaro
Old Feb 12, 2007 | 06:08 PM
2camvtec's Avatar
Well the easiest way is to buy some injector cleaner from your local autoparts store and follow the directions on the bottle.
Old Feb 12, 2007 | 06:12 PM
crxfornow2's Avatar
ok that sounds good im happy with what it is if i get it running right, its my daily driver now i couldent afford gas with the camaro, thanks for the help ill do it tommorrow also it may be leaking coolant from its brand new radiator so it may be the hose? ill pick up 2 of those tommorrow also for the total of $11.99 also the fuel tank me have a slight leak, how difficult is that to replace the gas tank in one of these clown cars, also can is it possible to seal it
Old Feb 12, 2007 | 06:22 PM
2camvtec's Avatar
Replacing the gas tank is not very hard, but it is not simple either. I had a gas tank leak in a 91 Integra and it ran fine until I changed it. Also if it is leaking coolant you would know. Are there any puddles underneath the car? Does it smell like coolant while driving?
Old Feb 12, 2007 | 08:42 PM
HF2ZC's Avatar
Also, try replacing the air and fuel filters. If one of these is clogged up the engine will run very badly indeed. As a matter of fact, clean out the airbox while you are in there replacing the filter, sometimes it can get clogged up with crap; especially if the car has been sitting. Mice tend to nest in places like that.
Old Feb 13, 2007 | 03:31 PM
crxfornow2's Avatar
Default Re: just bought crx rough idle cant keep highway speeds (HF2ZC)
update
wow checked the oil noticed it was way high so i just decided to change it, it took out over 5 quarts and filled it back up with 3, so it says its full on the dipstick, then changed the plugs and wires, everyone of the plugs was covered black and the first 2 were soaked in oil yes oil the person who had it befor me obviosly must of been at least 3/4 retarded but it runns good now difference of night and day thanks for the help
Old Feb 15, 2007 | 04:58 AM
crxfornow2's Avatar
ok so i got it out of the shop yesterday 800$ later now its good it needed new brakes all around the shoes pads and rotors and 2 axles but now its good
Old Feb 15, 2007 | 10:43 AM
ModelXRacer's Avatar
lol these crxs seem to be a money car... all kinda money required....
scarney
Jan 14, 2013 07:14 PM
rsfire
Classic Hondas
Apr 20, 2011 06:30 PM
wolfman_dlc
Sep 17, 2008 04:28 PM
hotinteggy
Sep 16, 2005 05:40 PM
