tranny whining
i drive a 98 ex with 63k miles and i noticed a loud whining so i automatically thought of the throw out bearing, the noise will go away wen the clutch is pushed in and will occur wen it is out, i was told that if it was the T.O bearing it would be loud wen the clutch is in and quiet when the clutch is out. any suggestions.. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">I think it may be your Main Input Shaft Bearing. It is pretty common to go out on EKs. </TD></TR></TABLE>
Sounds like it
EDIT:
AT OP:
Eh, it is, not much though, you have to drop the trans anyway.
Sounds like it
.EDIT:
AT OP:
924doorEG
Aug 27, 2007 02:07 PM
HomicidalHatchBack
10
Nov 11, 2006 05:47 PM
