troubleshooting temp gauge in 93 civicdx w/ ex clustert
Old Feb 12, 2007 | 03:34 PM
anavrin351's Avatar
Default troubleshooting temp gauge in 93 civicdx w/ ex clustert
The gas gauge and temp are in the same circle. Thje gas gauge works ( think, just put it in friday) but the temp gauge goes strait to over heat after a few blocks of driving. Hoping to get advise cuz dealership want 122 smackers for the single gauge. thats more than the cluster. If it is truly broken only option is junk yard i guess, but i would like to try to fix it if possable, thankls.
Old Feb 12, 2007 | 03:36 PM
I'm Trying's Avatar
Default Re: troubleshooting temp gauge in 93 civicdx w/ ex clustert (anavrin351)
could you be overheating? It could be a bad sender, I've had a bad sender before. It is right on the T-Stat housing.
Old Feb 12, 2007 | 03:37 PM
deadline's Avatar
maybe u just need to change out the temp. sensor rite under the dizzy....has the car had a head gasket blown before ?
Old Feb 12, 2007 | 03:40 PM
I'm Trying's Avatar
Default Re: (deadline)
the dizzy???
Old Feb 12, 2007 | 03:49 PM
anavrin351's Avatar
Default Re: (solbrothers)
the thing wouldnt run overheating like this. it runs fine and no probblems until i put the new cluster in. just in case though how much was the sender?
Old Feb 12, 2007 | 03:52 PM
I'm Trying's Avatar
Default Re: (anavrin351)
about 30.00
I'm Trying's Avatar
thanks never heard a distributor being called a dizzy before.
JackBlack2233
Nov 23, 2016 10:14 AM
1991hb
Sep 27, 2007 06:10 PM
Boofster
Dec 6, 2004 03:18 PM
MidwestSi
Jan 11, 2003 09:38 PM
