Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Powder Coating: First try.
Old Feb 12, 2007 | 03:22 PM
24boosted's Avatar
Default Powder Coating: First try.
Got bored today and decided I wanted to learn to powder coat.
Went out and got one of these from Sears.
Got some spare lugs to practice on. $150
Only color they had at Sears. bronze/dark gold. $6
Sprayed them and then into the oven. The gun works like a weak hair dryer and sprinkles the powder on.
Fresh out of the oven. $29 for oven.
Did some 5mm spacers as well.
Coated and non coated.
Applying clearcoat in the next couple of days.
Came out more bronze than gold, was easier than painting and no smell. Going to try larger items later on, my spare wheels will be next.
Modified by 24boosted at 4:40 PM 2/12/2007
Old Feb 12, 2007 | 03:25 PM
BabyCry31's Avatar
Default Re: Powder Coating: First try. (24boosted)
Thats good son! Keep me postD' yeah?
Old Feb 12, 2007 | 03:33 PM
Type X's Avatar
Nice work!
Old Feb 12, 2007 | 03:51 PM
skittle06's Avatar
Default Re: Powder Coating: First try. (Type X)
It looks like you need to hold the gun a little further away and spray lighter coats. The first lug nut looks a bit caked-on, like overspray. This happened to me the first, like 2 times, before I started spraying further away. Very good job though. Powdercoating material can be expensive but it's good to see people trying different things. Can't wait to see some of your other work.
Old Feb 12, 2007 | 04:27 PM
24boosted's Avatar
Default Re: Powder Coating: First try. (skittle06)
Yah Im still getting used to the thing. It splatters out sometimes or too little comes out.
Got any of your own to share skittle06?
Old Feb 12, 2007 | 04:58 PM
Caveman74's Avatar
How much was the kit and powder? $160.00 . I have seen some on ebay and was interested in trying it out.
Old Feb 12, 2007 | 04:59 PM
24boosted's Avatar
Default Re: Powder Coating: First try. (Caveman74)
http://www.sears.com/sr/javasr...e=Yes
Sears powder gun and about 7-20 bucks for the powder from ebay.
Old Feb 12, 2007 | 10:30 PM
JeShUa's Avatar
awesome.. hopefully you get it down
I'm sure if you do cool stuff you can have it pay for itself ;]
Old Feb 12, 2007 | 10:32 PM
BlueIntegraBoy's Avatar
How's the quality? Like professional powder coating?
Old Feb 12, 2007 | 10:51 PM
skittle06's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 24boosted &raquo;</TD></TR><TR><TD CLASS="quote">Yah Im still getting used to the thing. It splatters out sometimes or too little comes out.
Got any of your own to share skittle06? </TD></TR></TABLE>
Nothing recent, but I'm hoping to do my valve cover, when I get back home. I should have that up for you this week sometime.
Old Feb 13, 2007 | 06:45 AM
Demonis's Avatar
doesnt professional powdercoating bake at astronomical temps? like 800 degrees or such, thats why they always say no aluminum or low melt point metals.
Old Feb 13, 2007 | 07:00 AM
TRE_'s Avatar
Default Re: (Demonis)
Now you just need to figure out how to fit a wheel or valve cover in that easy-bake oven!
Old Feb 13, 2007 | 07:01 AM
Type X's Avatar
Default Re: (TRE_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TRE_ &raquo;</TD></TR><TR><TD CLASS="quote">Now you just need to figure out how to fit a wheel or valve cover in that easy-bake oven! </TD></TR></TABLE>
hahahah
maybe these will fit
Old Feb 13, 2007 | 08:50 AM
skittle06's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis &raquo;</TD></TR><TR><TD CLASS="quote">doesnt professional powdercoating bake at astronomical temps? like 800 degrees or such, thats why they always say no aluminum or low melt point metals.</TD></TR></TABLE>
It depends on who you go to. You really only need less than 500 degrees unless you're doing a very large part or multiple pieces. I think heating temp for something like a valve cover is like 300-350 degrees or something.
Old Feb 13, 2007 | 11:03 AM
B16B_coupe's Avatar
HRD PKR
Default Re: (skittle06)
wow.. altelast u can do all ur little parts in there. that looks good
Old Feb 13, 2007 | 11:24 AM
exbauer's Avatar
Default Re: (B16B_coupe)
that looks pretty good, thumbs up for having the ***** to try it.
Old Feb 13, 2007 | 12:40 PM
Hellzcivic's Avatar
So can I assume, that if your going to do your current stock rims, you would need to sand blast the current powder coating off, before you could powder coat again?
Just interested.
Old Feb 13, 2007 | 02:48 PM
24boosted's Avatar
Default Re: (Type X)
My friend has an old electric stove in the garage I can use for larger projects, not to meantion colleges have large industrial ovens.
Someone else shoved their wheel in their home oven. Here's a post from "the other site." Sickyute's work.
Heres the link: http://www.8thcivic.com/forums...kyute
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skittle06 &raquo;</TD></TR><TR><TD CLASS="quote">It depends on who you go to. You really only need less than 500 degrees unless you're doing a very large part or multiple pieces. I think heating temp for something like a valve cover is like 300-350 degrees or something.</TD></TR></TABLE>
Varies on the powder, average is 300-450 for 5-10 minutes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hellzcivic &raquo;</TD></TR><TR><TD CLASS="quote">So can I assume, that if your going to do your current stock rims, you would need to sand blast the current powder coating off, before you could powder coat again?
Just interested.</TD></TR></TABLE>
Aircraft paint remover will strip away all of the paint. Can be found at hardware stores.
Old Feb 13, 2007 | 03:18 PM
spoon-sports's Avatar
thats some tight ****....... im gunna go pick one of those up.
1QwIkEf
Honda S2000
Jun 15, 2008 12:38 PM
TehMan
Apr 16, 2007 10:19 AM
90h22acrx
21
Aug 15, 2005 08:32 AM
Cain Marko
Sep 17, 2004 02:30 PM
YEE*MagicEK20kombobomber
May 16, 2004 12:51 AM
