Rough Idle
Old Feb 12, 2007 | 03:11 PM
ProSlow07's Avatar
Default Rough Idle
My car is a 91 CRX HF and I cranked it up and it idled fine then I drove it to make sure the air pressure is good due to a low tire so I went home shut it off, went back out to check the oil and such, checked it..it's burning oil So I crank it and it idles at around 1200 then after about 30 seconds it drops to around 800..could it be the oil or are there other things involed? It has a flea bay intake on it that the previous owner so graciously dubbed me with so I had to fix that but hooking up a diffeent vaccum line to the engine because he had nothing there..any solutions??
Old Feb 12, 2007 | 05:36 PM
dr_latino999's Avatar
Default Re: Rough Idle (Deviant-CRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote"> So I crank it and it idles at around 1200 then after about 30 seconds it drops to around 800..</TD></TR></TABLE> That part seems absolutely 100% normal.
Old Feb 12, 2007 | 05:38 PM
Mavrick's Avatar
Default Re: Rough Idle (dr_latino999)
800 is a little low, does the engine shake?
Old Feb 12, 2007 | 05:40 PM
Default Re: Rough Idle (Mavrick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mavrick &raquo;</TD></TR><TR><TD CLASS="quote">800 is a little low, does the engine shake?</TD></TR></TABLE> Pssh, I aim my idle for the 750 area just to make it nice and smooth at idle. Did I mention quiet?
Old Feb 12, 2007 | 05:42 PM
Tippyman's Avatar
800 is perfectly fine, actually.
Ideal idle is 750 +- 50. So, 800 is just w/in spec. If anything, turn it down a little, not up.
sik_tC
Dec 20, 2008 01:20 PM
frog37_
Feb 15, 2006 11:34 AM
TurboSam
Oct 30, 2003 01:42 PM
freeplay
Sep 13, 2003 02:16 PM
zavalo
Feb 2, 2003 11:33 AM
