B16a OBD0, what EACV should be used?
Old Feb 12, 2007 | 02:50 PM
DustinRose's Avatar
Default B16a OBD0, what EACV should be used?
i have a JDM B16 OBD0, my EACV is throwing code, i want to replace it, no one has a straight answer on what EACV (electronic air control valve) to use. One person says the D16A6 works (88-91 Civic Si) others say to use the OBD1 94 Del Sol B16A3 EACV. the part numbers for OBD0 D16 and OBD1 B16 EACV's are different. if anyone actually knows, i will be shocked, please shock me
Old Feb 12, 2007 | 02:56 PM
DustinRose's Avatar
Default Re: B16a OBD0, what EACV should be used? (SunsetElixir)
Crx Jimmy's Avatar
Mine went bad too(on my b16) I just stole one from my junk crx-si motor's manifold. I also found later a spare I had from my 91 integra and it had the same bolt holes as the crx if that helps
Old Feb 12, 2007 | 02:57 PM
eda6's Avatar
90-93 teg or 94-95 del sol (dohc vtec) will work.
when you put a d series iacv on a b series manifold you can only tighten one of the bolts.
Old Feb 12, 2007 | 02:59 PM
DustinRose's Avatar
Default Re: B16a OBD0, what EACV should be used? (Crx Jimmy)
thanks for the reply, do you mean to say the the integra B18A EACV is what you used, or a D16A6 Si EACV?
Old Feb 12, 2007 | 03:00 PM
DustinRose's Avatar
Default Re: B16a OBD0, what EACV should be used? (eda6)
thank you very much sir, if anyone else has more info, please add to our discussion
Rex-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">90-93 teg or 94-95 del sol (dohc vtec) will work.
Old Feb 12, 2007 | 03:10 PM
mar778c's Avatar
Community Builder
Community Influencer
90-93 integra
Old Feb 12, 2007 | 03:18 PM
Crx Jimmy's Avatar
I dont know (maybe mine was different for some reason) but both the crx-si's d16 and the 90 integra valve were identical, bolt holes and all, come to think of it I put a d16 one on a 91 integra and it was fine, I think the dual point ones might be different but not the mpfi
IHEARTMYHONDA91
May 17, 2010 06:00 AM
Si-Samuri
17
Nov 15, 2008 10:03 AM
Serrano44
May 6, 2008 04:31 AM
jedubz
Sep 7, 2006 07:28 PM
postman
Oct 27, 2005 12:26 PM
