does anyone know how to remove an A/C belt on a 98 civic EX?
Old May 19, 2002 | 03:14 PM
Lei Siew Long's Avatar
Default does anyone know how to remove an A/C belt on a 98 civic EX?
i can't seem to find a bolt on there to make the bracket pivot to remove the belt. i removed the p/s belt but can't seem to remove the air conditioning belt. i referred to my manual but it is for a 92-95 civic and the layout is different for the 98 civic.
Old May 19, 2002 | 05:38 PM
TurboBumblBee's Avatar
Default Re: does anyone know how to remove an A/C belt on a 98 civic EX? (boostedeg6)
there should be a bolt on the ac compressor that will let you adjust it to tighten and loosen.. why are you removing the belts in the first place?? are you getting rid of the ac and ps all together? if so, get some sissors or a knife and cut it off..
Old May 19, 2002 | 09:27 PM
Plan B's Avatar
Default Re: does anyone know how to remove an A/C belt on a 98 civic EX? (C5_ALLMOTOR)
Somewhere on it, there is a tensioner, not on the compressor, but above it, right next to the side of the block. The tensioner can be raised with a 10 mm wrench to tighten it up. Or actually, I think the last time i did it, I actually loosened the bolt on the tensioner, and it came off that way. The power steering really makes it hard to do this, so if you can unbolt the ps pump, and move it out of the way, it would be easier, and only takes 2 bolts and 1 wingnut anway.
Well, that's how it is on my 94 ex anway. I think the d16y8 is pretty similar.
single_slam
Feb 23, 2014 05:40 PM
Tzarinque
Mar 2, 2007 07:40 PM
Integritycaptain90
Sep 26, 2006 07:24 AM
watacivic
May 23, 2006 09:18 PM
PerfectXtreme
Aug 2, 2003 10:41 AM
