Faulty alternator???
Old Feb 12, 2007 | 12:04 PM
stigedis's Avatar
Default Faulty alternator???
need assistance in what I suspect is a faulty alternator, but would like another opinion.
scenario is this:
went on vacation for the last week and had to park the honda (agnes as i call her) at the airport for the duration. Here in MN it was below freezing pretty much the whole time. I was thinking upon my return that a jump was going to be necessary. However, it was aboyt 20 degrees when we returned and she fired right up. No hesitation. I did however immediately notice the battery dash light was on. It was still during daylight hours. As i proceeded to drive home and it got dark out the lights were required. Upon my return to the driveway, she was all about but dead. Lights dim, tach not working etc. Turned off all that i could just to make it home. I chrarged the battery all night and still the battery light is on. I made sure the cells were filled with water. It was about 10 miles to home from the airport. I let the car idle before leaving the airport for like 10 minutes and ten minutes after returning home with no accessory stuff on. Need less to say I decided not to drive agnes to work today (40 miles away) in fear that the alternator is not working and she would suck the juice right out of the battery. There was no indication what so ever that their was any problems prior to my departure.
My questions are:
#1 does this sound like the alternator?
#2 anyway to confirm a faulty alternator besdies replacing it?
#3 Do alternators just die that quickly without warning? And perhaps the fact it sat out in the freezing temps expedite its death?
#4 Is it difficult to replace as a DIY? I am pretty mechanically inclned.
#5 what else should I be thinking here that could be the problem?
Thanks in advance!!!!
Old Feb 12, 2007 | 03:52 PM
stigedis's Avatar
Default Re: Faulty alternator??? (stigedis)
ps..
accord is a 1990 accord ex
thanks...
Old Feb 12, 2007 | 04:07 PM
hondadude's Avatar
It is real common for the brushes to get worn down in the ALT and make poor contact with the armature.
Cave man test is needed
When the batt light is on and the engine running smack the top of the alt. if the light goes out or flickers it is probably just a worn out brush pak.
the brush pak is under $30 and easy to replace.
Unhook battery negative
Swing the alt up, remove the battery connection and the 10mm holding the insulator and pull the insulator, unplug the connector.
the back cover comes off 8mm nuts.
Then you will see 2 phillips screws holding the brush pak in; use a really good phillips on them, they are tight, and you only have one chance.
Then use a feeler gauge to help slip the new brushes in over the armature.
onunezp
Jul 14, 2014 07:42 PM
stupendousman
Honda Civic (2001 - 2005)
17
Jan 2, 2013 08:40 PM
stevey40
Dec 10, 2010 06:55 AM
Bunny
May 24, 2009 01:16 PM
FlatlineSI28
Apr 22, 2008 07:25 PM
