bogging on accel
Old Feb 12, 2007 | 07:15 AM
Apocolipse269's Avatar
Default bogging on accel
hey guys ive recently had a problem of my engine bogging when i accelerate basicaly getting no power. any ideas? i can post more info later, im on my psp in class. thanks in advance
Old Feb 12, 2007 | 07:31 AM
pdiggitydogg's Avatar
have you messed with your tps/map connectors recently?
Old Feb 12, 2007 | 08:01 AM
Default Re: (pdiggitydogg)
no it just started last night out of nowhere. i did pop the hood and notice the thing that feeds air to the filter came off, but still the same problem. maybe new air filter?
Old Feb 12, 2007 | 09:37 AM
raphael's Avatar
happend to me too. id blame it on ur timing man hands down
Old Feb 12, 2007 | 10:02 AM
Default Re: (raphael)
k at home now, on regular compy. Here's a lil more information...
Basically its bogging slightly on idle, and in 1st gear its fine accelerating normally, then 2nd gear fine at first accelerating normally, if i try to accelerate more it starts bogging, and every gear up if i push gas too much it will bogg.
After Searching through forums i've seen ppl say replacing fuel filter will probally solve problem, so i got a new feul filter hoping it will (gotta go put it on) I'll Also Check my timing, which i dont believe to be the problem as nothing timing wise has changed since it started (just started doing it out of nowhere last night)
I'll Post with updates, any suggestions/comments well be very appreciated
Old Feb 12, 2007 | 10:11 AM
Default Re: (Apocolipse269)
Update: After reviewing Problem's Section in my Haynes Manual i came up with this:
<U>Engine Stumbles on Acceleration</U>
1 Spark Plugs Fouled
2 Fuel Injection System Faulty
3 Fuel Filter Clogged
4 Incorrect ignition timing
5 Intake Manifold air leak
ima check all of these
Modified by Apocolipse269 at 2:44 PM 2/12/2007
Old Feb 12, 2007 | 10:30 AM
YoungKadafi's Avatar
yea, thats like 1/20th of what it could be.
ignition system
timing
compression
fuel pump filter (not fuel filter)
fuel pump/injectors
exhaust leak
map/tps
Knock sensor
supertouch
Honda Civic (2001 - 2005)
11
Jul 20, 2007 10:19 AM
Xaero1369
May 20, 2007 12:31 PM
HImiles
Feb 17, 2007 11:49 AM
Prelude-TeCh
May 6, 2005 07:48 PM
civicboisi
Jul 22, 2004 04:22 PM
