clutch problem. please help.
Old Feb 12, 2007 | 03:26 AM
enzozenuni's Avatar
Default clutch problem. please help.
this morning when i went to turn the car on the clutch was very very loose. also when i tried to put it reverse it grinded the gears, so i pumped the clutch a couple of times and then it finally went into gear. after driving for a while it got somewhat back
Old Feb 12, 2007 | 05:59 AM
B18CchampHatch's Avatar
Default Re: clutch problem. please help. (enzozenuni)
anyones car here or there will grind a bit going into reverse, thats normal.
Old Feb 12, 2007 | 06:08 AM
THC07's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enzozenuni &raquo;</TD></TR><TR><TD CLASS="quote"> this morning when i went to turn the car on the clutch was very very loose. also when i tried to put it reverse it grinded the gears, so i pumped the clutch a couple of times and then it finally went into gear. after driving for a while it got somewhat back </TD></TR></TABLE>
check you fluids, master slave cylinder might be low
Old Feb 12, 2007 | 06:33 AM
hondaman86's Avatar
yeah It sounds like it could be a leak thats not allowing enough pressure to build up
Old Feb 12, 2007 | 06:38 AM
Chris EG's Avatar
Yep.. sounds like a fluid leak. Check the lines from the slave cylinder to the clutch master cylinder. Also check inside the car, sometimes the boot on the clutch master cylinder leaks.
Good Luck
Chris
88aeFC3S
Transmission & Drivetrain
Apr 13, 2009 03:21 PM
phatsindabuildin
Mar 25, 2008 06:57 PM
96WhiteOnBlack
Mar 26, 2007 07:15 AM
VOLTRONRacing
Nov 4, 2005 06:20 AM
