Eibach Pro-Kit Pics???
Old Feb 11, 2007 | 09:13 PM
96WhiteOnBlack's Avatar
Default Eibach Pro-Kit Pics???
I have a Pro-Kit still in the box and I have been wondering if I should go ahead and return it and get the Sportline. Pro-Kit- 1.3" drop front and back. Sportline- 1.7" drop front and back. I have a 4Door with 205/40/17s. If anybody has any pics with either the Pro-Kit or Sportline it would be great! Thanks guys!
Old Feb 11, 2007 | 09:31 PM
davidluko's Avatar
Ebaich Pro-kit springs on Tokico Illuminas:
Stock tire size... one major thing I don't like is that the rear is a little lower than the front, since sedans have mroe weight in the back vs. coupes. I bought the springs and shocks used together as a package but I'm hoping to swap the springs out for Skunk2 coilover sleeves soon and see how that rides and lower it a little more.
Old Feb 12, 2007 | 10:14 AM
VTEC420's Avatar
Default Re: Eibach Pro-Kit Pics??? (96WhiteOnBlack)
Eibach Pro's on KYB
And I don't have to worry about speed bumps or clipping my front air damn on a curb!
Modified by VTEC420 at 2:03 PM 2/12/2007
Old Feb 12, 2007 | 11:43 AM
jomama's Avatar
get the sportlines if you want to go lower... check my thread for a db8 with koni yellows and eibach prokit
Old Feb 12, 2007 | 01:54 PM
davidluko's Avatar
Default Re: (jomama)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama &raquo;</TD></TR><TR><TD CLASS="quote">get the sportlines if you want to go lower... check my thread for a db8 with koni yellows and eibach prokit</TD></TR></TABLE>
Aren't those a softer spring rate? I'd rather be a little higher with a stiffer spring rate personally, or if the Pro-kit isn't low enough for you (I want mine lower, plus I want to even out the rear with the front), then get something else that's low and stiff (which is why I'm putting the Skunk2 sleeves on).
Old Feb 12, 2007 | 02:38 PM
VTEC420's Avatar
Default Re: (Hatch_R)
The whole uneven thing always bugged me with these springs, I even checked to make sure I had em on right after I installed. I'll be getting a Progress or Tein set next. They've got some entry level setups for around 650...
Old Feb 12, 2007 | 02:49 PM
fergy016's Avatar
eibach pro-kit
kyb agx struts
stock blades with 195-55-15 tires
I got pictures with 18x7.5 motegi mr-7 wheels if you want to see what that stance is all about.
Old Feb 12, 2007 | 04:59 PM
mike5809's Avatar
Default Re: (fergy016)
how is the ride with the pro-kit, i just baught them and a set of tokico blues I have to put on.
Old Feb 12, 2007 | 05:17 PM
davidluko's Avatar
Tokico Blues are not performanc shocks so you might wanna return those... I have the Pro-Kit with Tokico Illuminas, set at 5 rear and 4 front (softest is 1, hardest is 5). It can be a little rough but not bad at all. I like it.
Old Feb 12, 2007 | 06:42 PM
hks369's Avatar
dont get eibach prokit it leaves your car 4ft too high eibach is great quality and ground control coilovers come with eibach springs so get those
Old Feb 12, 2007 | 08:43 PM
Default Re: Eibach Pro-Kit Pics??? (hks369)
I dont want coilovers and I dont want my car slammed. I want it to be practical with better handling and a lesser fender well gap.
Old Feb 13, 2007 | 09:42 AM
fergy016's Avatar
Default Re: (mike5809)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike5809 &raquo;</TD></TR><TR><TD CLASS="quote">how is the ride with the pro-kit, i just baught them and a set of tokico blues I have to put on.</TD></TR></TABLE>
It feels like it is stock. I am not liking the push effect on the front end when trying to corner hard. If your thinking about more agressive driving think about a stiffer spring set. If your looking for an everyday driver on the streets and a little lowered look, then this is your set.
Old Feb 13, 2007 | 09:56 AM
hondata151's Avatar
Old Feb 13, 2007 | 10:03 AM
So do you guys recomend I get new struts/shocks? I havent gotten any yet and hadnt really planned on it. But I see alota people gettin 'em when they put new springs on.
Old Feb 13, 2007 | 10:07 AM
VTEC420's Avatar
Default Re: (96WhiteOnBlack)
Definitely get new struts too. You'll probably blow out the factory ones real quick as they aren't valved properly for being lowered. It'll give a real bouncy ride as well without.
KYB's are pretty good on the cheap.
Old Feb 15, 2007 | 08:52 PM
fergy016's Avatar
Default Re: (VTEC420)
Stock struts aren't designed to be lowered. You will increase the pressure in the tube and the seal will start leaking.
You will get a much better ride on an aftermarket strut that is designed for a lowered ride height set-up.
Old Feb 16, 2007 | 05:28 AM
mike5809's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fergy016 &raquo;</TD></TR><TR><TD CLASS="quote">
It feels like it is stock. I am not liking the push effect on the front end when trying to corner hard. If your thinking about more agressive driving think about a stiffer spring set. If your looking for an everyday driver on the streets and a little lowered look, then this is your set. </TD></TR></TABLE>
Yeah this is for everyday. I did not want something to agressive or low. I drive 120 miles to work everyday. I just wanted something to lower a little bit and not be very stiff. I am not an agressive driver so I dont need to much performance. I used to have intrax springs and tokico illuminas on my da and that was way to stiff ( back then i didnt mind) but now it's not what I am looking for. Thanks alot!
Plus I have OEM Type R Front Lip, OEM Optional Sides, and OEM Rear Valences...so the car will be a bit lower to the ground then a stock car. That is another reason I did not want a drop over 2inches. It would be to low for me.
Old Feb 16, 2007 | 11:10 PM
dsuda's Avatar
I think eibach is a good product. I run an adjustable tokico "package" with illumias & their springs (made by eibach to their specs) & it could ride better both soft & stiff but for a daily drivin car its very livable & fun...
when this set up gives I think Im going koni/eibach.
kelviiv
Oct 12, 2008 11:26 AM
chau003
Oct 31, 2003 09:49 AM
gorilla nasty
Aug 17, 2003 06:47 AM
StevenTran305
Dec 24, 2002 08:55 AM
