B18c/b16 full swap minus tranny/wiring
Hey guys i'm trying to see what my motor is worth in value. I may be selling it to pay some bills I want it to be far but still good value for me. Thanks for your time guys.
NO SMOKE
GREAT COMPRESSION (9:8:1) with the block and head combination
good T-belt/Water pump
good plugs/wires
New intake/TB gasket
good cap/rotor
USDM B18C1 block
JDM b16a1 head
NEW blox intake manifold
NEW 65mm TB
GSR cams
AEBS head studs
OEM headgasket
OEM ITR oil pump
stock flywheel
ACT pressure plate stock disc.
full mounts
shift linkage
and inter. shaft with axles.
No exhaust manifold
No tranny
No wiring harness
Pretty much just need the above listed and it will fire right up I GUARANTEE it will fire and run with out any problems on the motors part that is
Thanks again guys i can get pics and awnser any questions.
Kevron
NO SMOKE
good plugs/wires
good cap/rotor
USDM B18C1 block
JDM b16a1 head
NEW 65mm TB
GSR cams
AEBS head studs
OEM headgasket
OEM ITR oil pump
stock flywheel
full mounts
shift linkage
No exhaust manifold
No tranny
No wiring harness
Kevron
