High idle on 87 CRX
Old Feb 11, 2007 | 11:39 AM
geneg69's Avatar
Default High idle on 87 CRX
I aquired this bad boy from my daughter. I have been unable to get the smog
completed in CA because of the high idle. It passes all other smog tests.
It idles at 1500 rpm. Trying to lower it with the carb idle adjustment makes it erratic and it dies out. I have replaced the carb with a good used one, The idle
relay and the throttle cable. The fast idle works ok. It does stall out a couple times
when the fast idle drops out, but when fully warmed up it runs OK.
The under hood idle spec is 750 +/- 50. It has a 5 speed manual tranny.
I have checked it for vacumn leaks.It has around 21 psi. I worked on American
cars but never a Honda before. I plan to restore this to its original condition.
Send me your inputs guys, I'll appreciate it.
Gene
Modified by geneg69 at 5:17 PM 2/11/2007
Old Feb 12, 2007 | 07:24 AM
bebo408's Avatar
Default Re: High idle on 87 CRX (geneg69)
http://www.g2ic.com/forums/sho...oting
good start if your fuel injected. dunno about carbs, use search forums too
Old Feb 12, 2007 | 05:11 PM
superex87's Avatar
make sure the timming is right
is it running rich?/ lean?
is there fuel coming out of the secondaires when its idling, if this is happening it will cause the engine to stall al low rpm's
also has any of the emitions devices been removed?
An awsome site to check out for first gen crx's (84-87) is redpepperracing.com theres tons of info of these neat little cars there
hope this helps
Old Feb 12, 2007 | 05:17 PM
JustAnotherRex's Avatar
This may help, general article on maintence and other questions like swapping: http://hondaswap.com/swap-arti...29108/
I didn't however see a direct answer to your question. Definitely check out redpepper racing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by geneg69 &raquo;</TD></TR><TR><TD CLASS="quote"> I have replaced the carb with a good used one, The idle
relay and the throttle cable. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bebo408 &raquo;</TD></TR><TR><TD CLASS="quote">http://www.g2ic.com/forums/sho...oting
good start if your fuel injected. dunno about carbs, use search forums too</TD></TR></TABLE>
Reading comprehension skills are good when you want to give advice too.
Old Feb 12, 2007 | 09:01 PM
geneg69's Avatar
Default Re: High idle on 87 CRX (JustAnotherRex)
Thanks for the inputs.I do need to check the timing again. On the smog check
it passed every thing but the idle speed. As far as i know all the emission
parts are there. I will go to the redpepperracing.com and see what they
suggest.
thanks again,
Gene
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
raene
Dec 23, 2002 10:49 AM
350z-tech
Nov 10, 2001 10:46 PM
