Bolt extraction
Old Feb 11, 2007 | 09:36 AM
andyt's Avatar
Default Bolt extraction
Any thoughts on how to get this bolt out?
Ok, sorry about the pic, here it is bigger.
Modified by andyt at 11:19 AM 2/11/2007
Old Feb 11, 2007 | 09:40 AM
uNF$@#!'s Avatar
Default Re: Bolt extraction (andyt)
too small to see what it is
Old Feb 11, 2007 | 09:42 AM
andyt's Avatar
Default Re: Bolt extraction (uNF$@#!)
Well click on it!
Old Feb 11, 2007 | 09:51 AM
LunchboxZT's Avatar
I don't have a login to we-todd.
http://www.tinypic.com
Old Feb 11, 2007 | 09:55 AM
neo_'s Avatar
Default Re: Bolt extraction (LunchboxZT)
We need to be a registered member to view that pic enlarged.
Old Feb 11, 2007 | 10:13 AM
erikiksaz1's Avatar
Default Re: Bolt extraction (neo_)
Use http://imageshack.us
wetodd and photobucket are always down
Old Feb 11, 2007 | 10:23 AM
RocknRon's Avatar
use an easy-out kit.
you drill throught the center and use correct bit to extract it back out.
You'll have to take out the bracket so you have room to work on it.
hope this helps
Old Feb 11, 2007 | 10:43 AM
Comp97GSR's Avatar
If that is what I think it is, a bolt extractor will not fit down there. What we did was removed the a/c compressor bracket/motor mount. Believe it or not I was able to use a screw driver and turned it out. If it is frozen, use the extractor.
Old Feb 11, 2007 | 11:07 AM
Kenso's Avatar
HT White Ops
Default Re: Bolt extraction (Comp97GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">Believe it or not I was able to use a screw driver and turned it out. If it is frozen, use the extractor.</TD></TR></TABLE>
Try using an angled pick or a small screwdriver, if you're lucky you may be able to unscrew it. If you undo the motor mounts on that side you might be able to get to it a little better from the bottom without fully removing the bracket.
Old Feb 11, 2007 | 04:17 PM
Mythias's Avatar
Default Re: Bolt extraction (Kenso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kenso &raquo;</TD></TR><TR><TD CLASS="quote"> Try using an angled pick or a small screwdriver, if you're lucky you may be able to unscrew it. If you undo the motor mounts on that side you might be able to get to it a little better from the bottom without fully removing the bracket.</TD></TR></TABLE>
I also used a screw driver in the past using the above method.
Old Feb 11, 2007 | 04:19 PM
BMaDOHC's Avatar
Default Re: Bolt extraction (Mythias)
take off that bracket and you should have plenty of meat to grab it by.
Old Feb 11, 2007 | 05:46 PM
andyt's Avatar
Default Re: Bolt extraction (BMaDOHC)
I got it out, just had to move the power steering stuff out of the way (remove bracket, etc), used a screwdriver to move it around, and fortunately it wasn't stuck.
The bolt broke while I was driving down the highway and the pulley fell, shredded the PS belt, and wedged itself in. I pulled over and removed the shredded belt and the pulley, the rest of the bolt was long gone.
And thanks everyone!
Trustfall990
Audio / Security / Video
Oct 11, 2006 06:32 PM
kidd_honda
17
Aug 5, 2006 07:52 PM
reed857
10
Jun 7, 2006 06:20 AM
az17xscrub
29
Apr 6, 2004 12:01 PM
