How can i replace thr front studs?
Old Feb 11, 2007 | 02:25 AM
androide016's Avatar
Default How can i replace the front studs?
I found another thread (https://honda-tech.com/zerothread?id=907985&page=1), is very helpful but I can't take out the hub on 00 accord LX. How can I take out? Is something holding besides the axle nut?
Modified by androide016 at 4:43 AM 2/11/2007
Old Feb 11, 2007 | 07:24 AM
Charri's Avatar
Default Re: How can i replace the front studs? (androide016)
if i remember correctly you need to have the hub pressed out? Someone correct me if i'm wrong.
Old Feb 11, 2007 | 08:41 AM
Centripital's Avatar
Default Re: How can i replace the front studs? (Charri)
Uh https://honda-tech.com/zerothread?id=907985&page=1 uses a slide hammer to take the hub out of the knuckle....AKA, it's pressed into the knuckle. This is the quick and dirty way of removing it. The proper way is to remove the entire knuckle from the car and use a press to remove it.
PS, the main purpose of the axle nut really isnt to hold the hub in the knuckle..
Joey.
Jul 5, 2006 04:44 PM
truesleeper
Apr 14, 2005 10:58 AM
ez_steezy
Feb 5, 2005 03:19 PM
typeeg
Jul 20, 2004 04:47 PM
integ u
Apr 25, 2004 12:37 PM
