re-using main and connecting rod bearings????
Old May 19, 2002 | 10:30 AM
jdmhatch94's Avatar
Default re-using main and connecting rod bearings????
is it a good idea to reuse the bearing or buying new ones when say your installing new pistons... or maybe i should say can u re-use them wihtout having any major engine probs???
Old May 19, 2002 | 12:27 PM
MrFatBooty's Avatar
Default Re: re-using main and connecting rod bearings???? (jdmhatch94)
It's always a good idea to replace the bearings. Technically you can re-use them if you inspect them and they check out as within service limits, but you might as well replace em since it's not like you get a chance to open up your motor on a regular basis.
nemesis25
Aug 2, 2012 11:30 AM
NA JDM GSR
Oct 16, 2006 10:22 AM
badCRX
Feb 12, 2002 10:13 AM
