2.0L B18c5
Old Feb 10, 2007 | 08:03 PM
cltitus's Avatar
Default 2.0L B18c5
I have search, i found nothing on Brain Crower Stroker Crank/Kit
I reall want to retain the 81MM bore but what to hit 2.0L i know the 95mm stroker will give it to me. I would retain the 11.5:1 ration.
question for those 2.0L guys why does everyone says overbore > stroke
whats the man reason you all choose this route.
thanks
Old Feb 10, 2007 | 08:06 PM
RTW DC2R's Avatar
what are your goals?? why so worried about staying 81mm?
Old Feb 10, 2007 | 08:07 PM
itralex's Avatar
Default Re: 2.0L B18c5 (cltitus)
Sleeve it and go overbore
engine life with the stock crank will shorten, but will not be as short as one with a 95mm crank
Old Feb 10, 2007 | 08:10 PM
cltitus's Avatar
going with a BC spec V complete P1 Head using BC headgasket. since im spending a crap load on head might as well built the bottom.
Old Feb 10, 2007 | 09:13 PM
neo_'s Avatar
Default Re: (cltitus)
It would be smarter to get sleeved to run a higher bore when going from a 1.8 to 2.0L . With a longer stroke, your bearings will endure more stress.
Old Feb 10, 2007 | 09:19 PM
cltitus's Avatar
for a na build i wouldnt have to go all out on some darton mid's
Old Feb 10, 2007 | 09:24 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">for a na build i wouldnt have to go all out on some darton mid's </TD></TR></TABLE>
Is that a question or a statement?
Old Feb 10, 2007 | 09:27 PM
cltitus's Avatar
kind of both, i always hear use darton mids but on peoples cars i see benson or rs sleeves
Old Feb 10, 2007 | 09:34 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">kind of both, i always hear use darton mids but on peoples cars i see benson or rs sleeves</TD></TR></TABLE>
Well Benson uses Darton sleeves. And if you want to go all out, get some sleeves from LA Sleeve Company. They have a tensile strength of 150000, with Darton being 125000. They are much more thicker and you can actually run a 87mm and plus bore relatively safe.
Old Feb 10, 2007 | 09:36 PM
MK Ultra's Avatar
Better to overbore.
Besides crapifying the rod ratio, stroker kits for the B-series use either billet cranks or modified cranks from the very old B20A, neither of which are as strong as the OEM B18 cranks.
Old Feb 10, 2007 | 09:38 PM
neo_'s Avatar
Default Re: (MK Ultra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MK Ultra &raquo;</TD></TR><TR><TD CLASS="quote">Better to overbore.
Besides crapifying the rod ratio, stroker kits for the B-series use either billet cranks or modified cranks from the very old B20A, neither of which are as strong as the OEM B18 cranks. </TD></TR></TABLE>
Look into Scat cranks, they are worth it.
Old Feb 10, 2007 | 09:50 PM
cltitus's Avatar
do you have a link to scat?
Old Feb 10, 2007 | 10:32 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">do you have a link to scat?
http://www.scatcrankshafts.com/
Old Feb 10, 2007 | 10:35 PM
cltitus's Avatar
yea i did some reading. the lowest stroke they have is 89. if im correct the stock is 87.2?
Old Feb 10, 2007 | 10:44 PM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cltitus &raquo;</TD></TR><TR><TD CLASS="quote">yea i did some reading. the lowest stroke they have is 89. if im correct the stock is 87.2?</TD></TR></TABLE>
LS/B20 = 89mm
GSR/ITR = 87.2mm
Old Feb 10, 2007 | 11:14 PM
grjp1988's Avatar
Like my pops said we have 3 cars over 850+ horsepower. 63 splitwindow vette drag car runs low 9's 69 camaro runs 10's "stick car"
and a 70 opel runs 8:40's all motor you get most of your horsepower from you head i was going to do a 2.0 stroke motor but then he told me you get most of power from the head now im just going to stay 1.8 put new sleeves in the motor and do the head to the max
Old Feb 11, 2007 | 03:07 AM
cltitus's Avatar
This is my head plan:
BC Spec V
P1 Valve Train
5 angel port/polish
port/polished IM
Extrode Hone the head/im
Old Feb 11, 2007 | 09:58 AM
92TypeR's Avatar
FSAE
I would say do both. Its only another ~$800 to add sleeves to that mess. You're going to take the motor to a machine shop anyways to do the hone for the new pistons right?
You should be quite happy with that setup. We've built some nasty 2.0-2.2L B-series using BC-V's.
Old Feb 11, 2007 | 10:49 AM
88 rex's Avatar
Default Re: (92TypeR)
I vote for bored out and using the LS crank
Old Feb 11, 2007 | 12:54 PM
doood's Avatar
been there done that
Default Re: (88 rex)
an 85x98 b series would be nasty
Old Feb 11, 2007 | 07:27 PM
cltitus's Avatar
Think i might go with LA Sleeves Overb bore to 85MM with stock stroke will put me at around 1979CC and with the headwork i should be able to hit around 240 - 250whp with proper tunning. Been thinking about toda's forge piston kit for the 85MM but they run a 13.5:1 think its a little to high for a daily drive beasty
Old Feb 11, 2007 | 08:17 PM
cltitus's Avatar
So Far as bottom end building:
Castillo's Crankshaft Specialist
Lighten Crank
Tear Drop Oil Dwells
Ion Harden
LA Sleeveing
85MM Bore with 1/8" (0.125) Wall Thickness
Toda
85MM Forged Piston Kit w/rings and pins
Import Builders
I-Beam Rods
OEM Honda Bearings
what do you people think about the starting of the bottem end.
Old Feb 11, 2007 | 09:18 PM
92TypeR's Avatar
FSAE
You are paying too much if you're going with the TODA piston set.
If you want a great combination, Manley Rods and CP lightweight's. Plus you can choose the compression you want.
Don't pay for a name, pay for the performance
Old Feb 11, 2007 | 09:26 PM
cltitus's Avatar
Spec v say 12.5:1 or higher. I always run 91 Chevron. is 12.5:1 or 13:1 Safe on 91 with proper tunning
Old Feb 11, 2007 | 09:42 PM
tONE.steR's Avatar
* B A N N E D *
All that money and hard work and a stock K20a2 w/ i/h/e swapped dc2 will still take you out and the K will last 3x longer than your motor.
You have one K'd... I say you boost the other one.
NA B-series is... "ehhhh"
