Header Coating
Old Feb 10, 2007 | 06:08 PM
gotboost562's Avatar
Default Header Coating
I have a header that had a crack by the collector. The crack was welded up and ground smooth. The area around the weld and the weld itself no longer has the protective coating on it. Should I just paint the area with hi-temp paint or is there a better solution? It was ceramic coated, or appears to be. Thanks.
-Mike
Old Feb 11, 2007 | 10:57 AM
Default Re: Header Coating (gotboost562)
Any suggestions?
Old Feb 12, 2007 | 02:17 AM
subydoored's Avatar
cermic coating inside and out try out these guys
http://www.hpcoatings.com/
Old Feb 12, 2007 | 09:40 AM
HiProfile's Avatar
Default Re: Header Coating (subydoored)
If the whole header was previously coated, I'd just use paint. I wouldn't expect more than 600* at that point. If nothing else, look into the tech line DIY coatings: http://www.caswellplating.com/aids/techline/
For just a smaller spot, it should be perfect. There's a few guys here that use that stuff, and it works great.
Old Feb 14, 2007 | 09:35 AM
mrlegoman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by subydoored &raquo;</TD></TR><TR><TD CLASS="quote">cermic coating inside and out try out these guys
http://www.hpcoatings.com/ </TD></TR></TABLE>
I'm going to have to suggest that you stay as far away from HPC as possible.
I have a Full-Race header that was treated at HPC and in less then 200 miles the coating started to fail. Instead of honoring their warranty, they made a general disclaimer that their warranty doesn't apply to Full-Race products. $300 wasted
HPC
As for your problem, I would also suggest just some high-temp paint. To get the entire header re-coated it would have to be completly cleaned and then coated. Probably an extra expense and a basic coating runs around 300$ anyway.
Old Feb 14, 2007 | 08:14 PM
greasemonkee's Avatar
High temp VHT will work wonders. If you're looking for a thermal insulation, this is what you're after. Spray it on lightly - too much and it will flake off. Be sure to get the high 2000*? VHT.
Old Feb 15, 2007 | 10:25 AM
HT Chaplain's Avatar
Loved
Default Re: Header Coating (mrlegoman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrlegoman &raquo;</TD></TR><TR><TD CLASS="quote">
HPC
As for your problem, I would also suggest just some high-temp paint. To get the entire header re-coated it would have to be completly cleaned and then coated. Probably an extra expense and a basic coating runs around 300$ anyway.</TD></TR></TABLE>
Yeah if your going to coat anything use Swain Tech coating. the best coating by far. Alll the others are just high temp paint
Old Feb 17, 2007 | 02:42 PM
Sikocivic's Avatar
Default Re: Header Coating (HT Chaplain)
I went to a place that sells wood stoves. They have a lot of different colors of paint in spray cans. I painted my downpipe and turbo 2 years ago and it is still holding up. It hasen't even changed color. GREAT stuff.
lando griffin
Apr 13, 2009 09:16 AM
category5 SI
Oct 21, 2007 12:41 PM
xmr. robotox
Feb 27, 2005 07:08 PM
nY's FiNeSt
10
May 16, 2004 08:23 AM
TypeRuz
Apr 24, 2004 01:52 PM
