shif knob/linkage broken? i can pull it up and down... wtf?
Old Feb 10, 2007 | 04:45 PM
verbal assassins's Avatar
Default shif ****/linkage broken? i can pull it up and down... wtf?
shift **** was sitting soo damn low, i didn't know what was wrong. so i tried to reverse my car, but couldnt, then i thought, hmmm... maybe i should pull it up, and what the F do you know?
the entire ****+linkage went up and i can put it into reverse...
wtf happend here? did a bolt come off or what? its basically sitting real damn low and i need it back to the stock position...
need help asap.
Old Feb 10, 2007 | 04:54 PM
RS'R''s Avatar
ye, the bolts that attach the shift linkage under the boot are loose or may be gone. jack the car up, take a look right under the shift boot. youll probably need 2 i think size 12 bolts
Old Feb 10, 2007 | 05:10 PM
Default Re: (RS'R')
what part #?
i dont see it on this pic.
Old Feb 10, 2007 | 05:27 PM
tomithy's Avatar
looks like it might be 26 but i'm not sure.
There are 2 bolts under there and i'm pretty sure that they either fell off or are very loose. One of my bolts fell off and I bought a replacement from autozone. I still had one of the bolts though so I brought it in and got a matching one. I don't remember what size it was.
Old Feb 16, 2007 | 01:02 PM
Default Re: (tomithy)
anyone else know what might be the problem?
don't i need all these parts?
#26
i asked a mechanic and he said he would have to take a look at it. i don't want him BSing me so thats why im asking if i would need those parts, or something else might be up... OH YEAH. my car use to be an automatic.
Old Feb 16, 2007 | 01:06 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
hmm auto to manual swap, yeah that could be part of the problem.
I'm not sure if the bolt holes are already there for the shift linkage or not when you do a manual swap, but I'm guessing they are. Just get under the car and look at the shift linkage at the end where it bolts to the car (where you see the #26 bolts and the #18 bushing) and see if anything is missing.
Old Feb 16, 2007 | 01:39 PM
JDMorgan's Avatar
did it ever work normal? it sounds like you are missing both 26's and the linkages are just sitting there. 19 may be gone too depending how long you drove with no bolts but it generally stays on there pretty well. you shouldnt need anything else tho.
Old Feb 16, 2007 | 02:25 PM
Default Re: (JDMorgan)
yes, it was working normal for a good 5-6 months. after i got my car back from the dyno run, it came back like this and i didnt really notice it until i tried to reverse.
so, all i need are the bolts... i jack my car up and see if i can see anything.
Old Feb 16, 2007 | 03:59 PM
JDMorgan's Avatar
yea jack it up and see if the metal bracket(19) is still on the rubber bushing(18).
mattbatson
14
Feb 12, 2012 05:12 PM
umair
Mar 27, 2009 03:27 PM
girliehonda
Sep 26, 2007 08:15 AM
mymeatb18"
Oct 30, 2005 10:35 PM
Unjockable
Apr 24, 2002 10:13 PM
